Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 03-15-2005, 05:49 PM
Tech047 Tech047 is offline
SVT parts in Zetec motor?
My question to anyone with input is, can the Zetec block fit an SVT head and are the bolt patterns the same? If not, can the SVT cams be used with the Zetec head?
Old 03-15-2005, 07:47 PM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
Re: SVT parts in Zetec motor?
They have the same block, so yes. SVT cams would work, but there are many other options too.
-Chuck
Old 03-15-2005, 09:51 PM
nose-gobblin's Avatar
nose-gobblin nose-gobblin is offline
Send a message via AIM to nose-gobblin
Hmm never though of that, pointless thoug really unless u get the getrag 6 speed to go with it
2001 Ford Focus SE LIMITED EDITION.
-Laser Red
-5 Speed Manual Trans.
-Fully Loaded
-XM Sattelite Radio
-APC Euro Tail Lights
-JVC Deck w/ Motorized Face
-Falken ZE512 205-50-r16 91v
-Interior Glow Lights
Old 03-15-2005, 10:05 PM
focusyn focusyn is offline
Re: Re: SVT parts in Zetec motor?
I believe Ford worked some magic on the SVT head ( it's really the same head, isn't it?) compared to the stock Zetec. The SVT motor is just a massaged Zetec.
Could changing a base Zetec to SVT cams cause computer problems or can the computer adjust to the cams? I imagine doing all this, you'd probably be considering a new chip anyway.
The sixth gear wouldn't be the problem, the 108 mph speed limiter in the base ZX3 would be if it wasn't changed. Unless you don't plan on going over 108.
As Mustangman put it, there are lots of options for tuning both SVT and the stock Zetec engine.
Old 03-15-2005, 11:32 PM
Maybe, but I can't see how a more agreesive cam could be a bad thing either way. Especially considering the car will be getting boost by mid spring. Just considering it as an option.
As to the speed limiter and the stock computer. My brother found an excelent piggy back that should help cleap up the air/fuel and also controls ignition timing and rev limits... I should be able to overide the speed limiter with it as well.
Thanks for all of your input...
Old 03-16-2005, 06:44 PM
PsykoDemun PsykoDemun is offline
As it seems to follow the same thread of thought: What about swapping in the SVT exhaust from the header back? I'm sure you'd have to make your own supports, but what about attaching it to the head? From what I've heard the shorty headers a ZX3 needs burn out cats and it'd be nice to have the cat moved further down the exhaust.
Old 03-16-2005, 08:10 PM
For any exhaust on the Zetec Focus, (if the money is available) I would get a full length race header, then attach the cat further down in the exhaust to pass inspection...it really sucks that the cat has to be directly after the exhaust manifold on the Focus...
-Chuck
Old 03-17-2005, 01:55 AM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
the intake cam wont fit w/o the head the intake cam was designed to fit a head with the VCT
Old 04-03-2005, 11:58 PM
vintweed vintweed is offline
Send a message via MSN to vintweed
The SVT cams won't work, as the SVT has variable timing, and the regular Zetec does not have the accomodations for the extra parts...
The SVT head should work though (but you might need to swap ECU's as well, to control the cams and the DSI
Old 04-04-2005, 05:15 PM
Banned
didnt i just say that? and you dont need VCT to work, if you dont want it
Old 04-11-2005, 02:46 PM
OK! Don't get sassy Escort man! Why the hell, you replying to SVT questions anyways...is one parked beside your ZX2 or????
Old 04-12-2005, 12:00 PM
Banned
Re: Re: Re: SVT parts in Zetec motor?
Cuz you don't have to own a car to know about it, and I know zetec engines, and VCT equiped VCT zetecs better. I happen to have one.
Old 05-01-2005, 12:32 PM
redchev2005 redchev2005 is offline
why wouldnt you just swap with a svt motor realy all this is a waiste of time you would be better off turboing the 4clylinder than doing all this svt shit its not worth it?
Old 05-01-2005, 06:43 PM
Was that English? If I'm understanding you correctly, then you are mistaken, since the SVT is also a 4 cylinder...
-Chuck
Old 05-02-2005, 06:41 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
i think he means would it be more benifical to just turbo the non svt zetec opposed to swapping a svt zetec into a regular zetec focus.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
