Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-15-2005, 04:32 PM
Caper74ca Caper74ca is offline
1996 contour need help
i have a 1996 ford Contour that you need to use 2 feet to drive it when making a stop or it will stall .Any help on what this can be ???? or a few things that might cause this . thanks for your help
Old 03-15-2005, 06:36 PM
Jason43's Avatar
Jason43 Jason43 is offline
Re: 1996 contour need help
Not sure what you're asking here. I'm assuming this is an automatic and you have to give it gas when you hit the brakes?
Just go to contour.org
1999 Ford Contour SVT
Old 03-17-2005, 07:06 PM
Re: Re: 1996 contour need help
Hi sorry for confusion ..... yes it is automatic and yes i have to give it gas when i put on the brake ...gotta drive wit 2 feet lol thanks for any help
Old 03-17-2005, 09:13 PM
JoeyBoy JoeyBoy is offline
It could be plugs, wires, fuel filter, etc. Maybe a full tune up would help. Change the plugs, wires, air filter, and fuel filter and if this doesn't work, go to AutoZone and have a diagnostic ran on the car, it is free.
Old 03-17-2005, 11:04 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
what engine does it have? Once you blurp the throttle, does the engine "catch itself" and run fine again?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-19-2005, 09:18 AM
frankjc frankjc is offline
probably the MAF sensor.
clean it off, and try it, don't use carb cleaner.
