I am having trouble with a 04', v6, manual tranny Tacoma with cranking. The dealer replaced a wiring harness to the fuel pump and fuel line under a recall.
Originally I was experiencing trouble with crank times ( 3-8 seconds, similar sound to a dead battery crank) when the under side of the truck was wet. The dealer fixed the problem, and it went away for about a month. now the problems back.... Took the truck back to the dealer and the dealer called Toyota and the Tech's there said that a delayed start like that is "normal" (3-8 seconds) and did no actual work other than run the diag. and call Toyota. Here is the write up from the dealer: "checked fuel pressure - no bleed down engine crank time is normal. 5x2 te v-6 engine only has 1 signal on cam and crank shaft has to turn double in order to put cam signal again. called Toyota tech assistance, vehicle is starting as designed." I agree with cam having to align to complete the circuit and fire the engine, however I dont not agree that it should take 3-8 seconds to align the cams and fire. The other thing that leads to believe that there is a problem is that the dealership said that clutch pedal position can be affecting the start. I know there is a switch on the pedal that has to make contact for the motor to start and I know that my foot is to the floor on starts. ( pedal not depressed, no movement of motor etc.) My question is 3 fold.... Does anyone have this problem of a long start (does not always happen)? Does anyone know what the problem is? Is this long crank cycle normal for the V6? |
Toyota Supports ASE Certification
EG042-04 Title: INTERMITTENT EXTENDED OR HARD" CRANKING Models: 03 04 Tacoma (V6) Technical Service BULLETIN September 20, 2004 Some 2003 2004 model year Tacoma (V6) vehicles may experience an intermittent extended or hard engine cranking at startup. A revised engine wire harness and ground point relocation is required to correct this condition. http://www.automotiveforums.com/vbul...d.php?t=203356
.........\\|//........ ........(@ @)........ ...o00o_O_o00o... ..Due to budget cuts.. ..the light at the end.. ...of the tunnel has... ....been turned off.... |
I can send you the whole TSB if you would like thur e-mail, it is like a 10 page bulletin on it for 03/ 04
Re: 2004 Crank time... HELP!!!!
Plumber546-
Thanks for the info. They replaced the harness, I know anythings possible, could the new harness be defective? Is there a specific wire/connection point that I can check on my own with the Fluke to verify a faulty wire? you can pass along the Bul. [email protected] Thanks |
I sent 2 PDF file 1 for the fuel and 1 for the engine wiring harness
