Old 03-15-2005, 03:10 PM
Scott82 Scott82 is offline
Is there a way to find the answer?
Ok, here's the question, and its not real important, it would just be nice to know. Is there a way to trace a motor from Japan to find out exactly what year it is. Are there identifying marks on an engine that can tell you exactly when the motor was new and possibly which model car it came out of. I my case i have the D15 Vtec from japan, and the only engine code mark that i have is down on the block and it says ZC, but no numbers. Anyone have any ideas?
Old 03-15-2005, 04:07 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Is there a way to find the answer?
The year is marked on the front of the block like this: http://img.photobucket.com/albums/v4.../blockdate.jpg (that's a '96)
The ZC is your engine code; you don't have a d15 vtec, you have a ZC.
Old 03-15-2005, 04:22 PM
Thanks man i apreciate it, can you kinda explain how to read these dials and where exactly are they located.
Old 03-15-2005, 04:29 PM
CivicSpoon's Avatar
There is no Spoon
It's right at the center of the block, right above the exhaust manifold. Just look at the left mark where it's got the 9|6 ("|" being the arrow); that motor is a '96.
Old 03-15-2005, 04:42 PM
BullShifter's Avatar
Re: Re: Is there a way to find the answer?
ZC is a NON-VTEC 1.6L
Old 03-15-2005, 04:47 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
There are also SOHC ZCs with VTEC... I didnt believe it myself, till I saw pictures of one...
Then theres this thread on H-T, which explains the differences between the SOHC ZC (VTEC) vs the D15B VTEC... Main difference is the .1 liters... D15B has 1.5 (obviously), SOHC ZC VTEC has 1.6...
http://www.honda-tech.com/zerothread?id=1087149
Old 03-15-2005, 09:03 PM
i have the ZC Vtec, at least it says it on the valve cover and there is a vtec solinoid on it too, so i am pretty sure its vtec
