Go Back   Automotive Forums Car Chat > Ford > Probe
Old 03-15-2005, 02:30 PM
Dani1025 Dani1025 is offline
Send a message via AIM to Dani1025 Send a message via MSN to Dani1025 Send a message via Yahoo to Dani1025
94 Probe over heating
I just bought a 1994 Ford Probe SE. IT needed a new waterpump, belt, thermostat and raditor cap. I had all these repairs done and it STILL over heats. IT mostly over heats when I"m driving put when I"m stopped at a traffic light or something with the car running, the temp gauge goes down. Can anyone give me some adive on what it might be. Thanks a lot.
Old 03-15-2005, 04:18 PM
96probegt's Avatar
96probegt 96probegt is offline
Re: 94 Probe over heating
check your radiator fans
Old 03-18-2005, 04:00 PM
bhoward86 bhoward86 is offline
Same thing is happening to my 91 Probe lx and I changed the spark plug wires, water pump housing, thermostat, and it still over heats.
Old 03-20-2005, 02:42 PM
Doc_Ratchet's Avatar
Doc_Ratchet Doc_Ratchet is offline
Send a message via AIM to Doc_Ratchet
From the sounds of it, you may have a bad head gasket, or one that's getting close to going bad. If you've changed the water pump & thermostat, disconnect both the upper and lower hoses, plug the outlets on the radiator, and flush both the radiator and the entire cooling system with a garden hose to ensure the water can circulate. Then refill the system with fresh 50/50 mix, and if it still overheats, you just may be looking at a head gasket.
