Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 03-15-2005, 01:52 PM
bblaundry bblaundry is offline
Another Driver's Side Window Problem
I know this issue has been discussed a few times, but I getting conflicting information.
All of my window controls on the driver's side are not working. The switch on the passenger side seems to be working fine. So, I'm not sure if I should be focusing on the switch module on the driver's side, or the motor. I'm leaning towards the switch.
How big of a job is this to change?
Where can I find a wiring diagram or schematic?
Thanks all
Old 03-15-2005, 09:11 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Another Driver's Side Window Problem
To change the switch on the driver's side all you need to do is gently pry up on the plastic panel that holds the switch on the door. Remove the wiring harness to the switch and then remove the switch from the trim panel. I had one do the same thing on one of my vans and it turned out to be the master switch on the driver's side also.Upon further research i discovered that it is a problem for these vans as water and moisture can affect the switch because of it's location,( and if you like to leave your windows open all the time, letting the rain in the vehicle.) If you can wait a few days, you might want to check prices locally, then online. I got a great deal on a GM switch from an online dealer, with shipping it was over $25 cheaper than any price I found locally.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 03-17-2005, 11:36 AM
chicksmom chicksmom is offline
Re: Re: Another Driver's Side Window Problem
Those pictures are great, where do you live?? Looks like they have a problem with the street painters!! LOL
Old 03-22-2005, 12:53 PM
Thank you very much for the simple explanation. I'm sure moisture is the issue. Being in Western NY, snow tends to get inside the door quite often. I'll give it a whirl this weekend.
What online dealership did you use?
Old 03-22-2005, 11:03 PM
Re: Re: Re: Another Driver's Side Window Problem
I hear ya. I'm down the Thruway in Central NY and we do get our share of snow and surprise rainstorms in the summer when we leave our windows open. I have used a few online dealerships in the past with good luck. I can't seem to remember which one I got the switch from, but I'll give you the names of the ones I have used and all you have to do is go to their site and go through their online catalog. From there you can get the price and compare them to see who has the best with shipping. www.buygmparts.com www.parts.com are 2 that I have used in the past that first come to mind.
Old 05-06-2005, 10:30 AM
Re: Re: Re: Re: Another Driver's Side Window Problem
Hello,
I finally got my switch module from gmpartsdirect.com. I put it in and unfortunately, the problem is unchanged. I have no window control on the driver's side, but the passenger and lower/raise his window. Does anyone have wiring diagram for this system? Could this simply be a fuse issue?
Old 05-06-2005, 05:05 PM
GregA's Avatar
GregA GregA is offline
Re: Re: Re: Re: Re: Another Driver's Side Window Problem
Hello,
I have a schematic that I will be putting up soon.
Not the fuse -- one fuse (circuit breaker actually) is used for both sides.
From what I can see, your driver's side switch panel is probably NOT getting power (12 Volts) through the wire harness. My manual says it is supposed to come in on pin "H" of the connector of the driver's side (should be one of the corners on the connector) and pin "F" on the passenger side. My GM manual says the wire should be Yellow (but Haynes says Brown).
I believe the passenger's side works because the 12 Volts comes directly from the circuit breaker to that switch panel through the wiring harness.
But the "good news" is -- it appears that the ground for the passenger side switch actually comes through the driver's side switch. So the wiring between the left & right side is probably OK.
I would use a meter (or test light) to see if the power is making it to pin "H". It should be there with the key in the "Run" position. I suspect a loose or broken connection.
I will post another note once I have the schematic on the web, but let me know if you find the problem first.
Take care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 05-06-2005, 06:25 PM
GregA's Avatar
You can find the schematic/wiring diagram here:
http://www.links-to-golf.com/van/dri...-switches.html
I also confirmed that the color of the wire is yellow (at least on my 2001).
Take Care,
Greg A.
Old 05-10-2005, 08:11 AM
Take Care,
Thanks for all of the info. It really helps...and now it makes sense. I'll take a look at it tonight.
Thanks again.
Old 09-07-2005, 10:54 PM
tinytina tinytina is offline
Unhappy Re: Re: Another Driver's Side Window Problem
Thanks again.
Hi there, I also have a chevy venture, 2000, and am having the same problem as you were (are) can you please tell me if you actually got the problem solved and if so what was it so that i can fix mine too!
thank you in advance for your help.
Distressed over van!
Tina
