Old 03-15-2005, 12:07 PM
JoshBarber JoshBarber is offline
Fuel level sensor
Has anyone found a way to replace or fix the stock fuel level sender so that it's not so erratic? It drives me friggn crazy moving from 3/4 a tank to 1/2 in a half a second....stays at 1/2 for a day without much movement, and all of a sudden is almost empty within seconds.
Is there an aftermarket one thats more consistant? Or a fix to the stock one?
Old 03-15-2005, 03:13 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Fuel level sensor
Replace the sending unit.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-16-2005, 06:43 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
If you have the original fuel pump still installed, you can only use a level sensor unit from GM. (I got mine from GMpartsdirect for $72.00, it's $120.00 at my local Chevy Stealer). That sensor worked fine until my pump housing broke at the fuel line input.
The aftermarket pump assembly I have is made by Carter (Federal-Mogul), and the level sensor is completely different from the stock A.C.Delco unit (not interchangeable). The Carter sensor unit is a more robust design than the A.C.Delco unit. (~$300.00 at Napa, the 4 door assembly is $30.00 less than the 2 door assembly)
Whichever way you go, make sure you get the correct pump assembly or level sensor unit, as they are different units for 2 door and 4 door models.
After having to drop the tank 3 times over the past 4 weeks, I got the changeout down to a 2 hour task.
