Go Back   Automotive Forums Car Chat > Buick > Century
Old 03-15-2005, 11:28 AM
wldwest75 wldwest75 is offline
Question 1990 buick century won't start
My grandma has a 1990 buick century and she was driving about 60 mph hour and it just died. It didn't get hot or anything just quit.Any ideas what it might be?
Old 03-15-2005, 12:09 PM
MoNsTeR`ImPaLa MoNsTeR`ImPaLa is offline
Re: 1990 buick century won't start
crank sensor ?? fuel pump ?? timming chain/belt??
eask check turn the car over then remove valve stem cover on the left hand side of the plenium pusg down in the little valvle ( like the on on the tire ) if it sprays gas then the pumps good if not you have to replace the pump btw i have a 91 ready for the wreckers if you need parts lmoa new everything lmao
Old 04-05-2005, 05:26 PM
It has fuel pressure and spark but still will not start . And its not the timing. The gas gage said it had a half of tank of gas. but we checked and it was empty. So we put gas in it and it still wouldnt start.
Old 06-09-2005, 09:16 PM
rdhanley rdhanley is offline
Re: Re: 1990 buick century won't start
is there any fuel coming out of air breather area or anywhere else it is not supposed to.
if so , probably a bad fuel pressure regulator.
Old 06-09-2005, 09:37 PM
tri-power's Avatar
tri-power tri-power is offline
If you ran the tank dry there is a possibility you burned up the pump. Try hooking up a fuel pressure gague to the schrader valve on the fuel rail and turn the car on. You'll need to know what the specified pressure rating is for your car. The test is best performed when the engine is running but at least you could get a ballpark idea that the pressure is right. Just remember the pump may still run but may not run enough to keep the engine fed. I would not suggest just opening up the schrader valve and letting it spray. The test is innacurate and dangerous.
Old 06-10-2005, 11:15 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Have the crank position sensor replaced. This is a usual symptom of a CPS Failure in that the car will stop while driving. The advice you received on the fuel pump is right on but if it checks out OK then the CPS will be your best bet.
