Old 03-15-2005, 10:06 AM
Rextar Rextar is offline
Irratic idle and such
Hello,
I have owned a 1991 Firebird for about 2 years now and have been having this idle problem for as long as I can remember. Basically, when you first start it, it idle's really high like up to 1800 RPM sometimes. Eventually it will go down but then the problem is the idle is very irratic and when I am at a stopsign for example or a redlight just sitting there the idle will fall and the car will just stall. Most of the time it high idles. And like I said the idle is just so irratic. So far we have had the timing checked (was off by 10 degrees but fixed) put a new ECM in, put a new ISC in, and a few others things I can't remember right off the top of my head. We've also noticed the engine running very lean lately. I also was thinking it might be the IAC valve. Anyhelp would be so appreciative this thing has been a pain in my butt from the time I bought it.
thanks,
Steve
Old 03-15-2005, 10:47 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Irratic idle and such
Welcome Steve and the IAC would be my first guess.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-15-2005, 10:59 AM
thanks alot!
Old 03-15-2005, 12:33 PM
Turns out I already replaced the IAC valve and apparently forgot. Because I went to go look at it and it looks brand new (and I also remember putting it on now) so I guess that isn't the problem with my irratic idle. But I was just doing some more research and I was reading a bad EGR valve can cause a rough idle. Anyone know if thats a possibility?
Thanks,
Steve
Old 03-15-2005, 02:54 PM
Live702's Avatar
Live702 Live702 is offline
Don't know about the EGR valve, I had a similar problem with my 89. Turned out to be the coolant temperature sensor. It was getting no low temperature input, so the ecm revved the engine really high, thinking it was very cold out.
- 1989 Trans Am GTA
Old 03-16-2005, 12:38 AM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
take some carb cleaner spray it around ur intake, and throttle body or injectors or whatever u have. if the idle goes up u got urself a vacum leack cuz vacum leaks are known to affect idle like u describe.
Old 03-16-2005, 06:23 PM
99onI95's Avatar
99onI95 99onI95 is offline
Currently my car has an irractic idle. Its probably a crack in the intake. Or atleast that is what I was told.
2010 ALCAN 5000 driver
I own or have owned:
98 Ram Air firebird-WS6 hood and rear decklid, WS6/C5 vette rims, etc.
03 SRT 4-3'' exhaust, short throw, injectors, matte black
E36 convertible BMW-05 17'' BMW wheels
02 Volvo S60 AWD turbo-Stock
00 Audi A6 4.2L V8 Quattro-Potenzas, straight pipes
03 C240 Benz 4matic-stock
04 2.5rs Impreza
05 Chrysler 300C HEMI
04 GSXR-Power commander, K&N, gears, crash cage, suspension, LED tail
Old 03-16-2005, 07:51 PM
custom mccannix custom mccannix is offline
Send a message via AIM to custom mccannix
when you put your IAC in did you set the plunger to the specified postion, or length? You may need to get the specs and reset it.
