Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-15-2005, 08:58 AM
inmavt2 inmavt2 is offline
Power window speed
I have a 2000 MGM and I find that all of the windows speed varies with the temperature out side. The colder it gets the slower all the windows go. this can get to the point where the windows almost don't make it up and down. Does any one know a fix for this problem or is it one of those things I have to live with... I hope I am not alone with this problem and some one out there can help.
Old 03-15-2005, 12:21 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
trys pressing the gas a lil when u put the windows up i have the same problem but mines a 92 but i wouldnt wry anout it
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 03-18-2005, 10:50 PM
76CDV 76CDV is offline
My 2000 GM has the same problem. When the outside temperature is lower than 25 degrees F. or so, they become painfully slow to roll up. The charging system is working fine. I took the car to the dealer and their solution was to spray the window guides with silicone. That didn't help. I think the motors are just too weak.
Anyone other ideas out there?
Old 03-19-2005, 10:37 PM
JCLessard JCLessard is offline
Re: Power window speed
I live in Canada where the temperature qets down to -40 F. The window tracks (Guides) come coated from factory with white lithium grease. Unfortunatly, this grease type freeze. I have cleaned the guide with solvent and replace the white lithium with synthetic grease. Dialectric grease (Clear grease also used for lubricating disk brakes and ignition components) works fine too.
Cheers
JC
Old 03-31-2005, 08:59 AM
Re: Re: Power window speed
I finally got around to trying the solution of cleaning the guides and replacing the grease...worked great... thanks for the help!
