Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-15-2005, 06:25 AM
nova1313's Avatar
nova1313 nova1313 is offline
O2 sensor wiring.
This may be a long shot but I figured I would ask. My check engine light came on and I found out it's the bay 1 o2 sensor ( before the cat) so I picked one up... slight problem with the wiring though. The guy said just match up the colors. Easier said then done...
The car behind the connection on the current one has wires colored red, black, yellow, white
The old sensor that plugs into that has wires white, black, black, blue
The new sensor has wires that are white, white, black grey.
I didn't think to write down how the old and new ones are connected but I can check later.
I'm just at a loss and I didn't get to pickup a haynes manual yet..
Any help would be appreciated and if you need more info let me know. I can get the order the wires are currently connected later.
_____________
99 Eclipse Spyder GS
5 - Speed
Stock (so far)
Old 03-15-2005, 07:18 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: O2 sensor wiring.
Can you return it and pick one up from the dealer?? That way it's "plug and play". As far as which wire is which, I don't know.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-15-2005, 08:43 AM
nova1313's Avatar
only one mitsu dealer in my area and for sensor they wanted to charge me 50 bucks more then this one cost. :/
I'd like to exhaust all other options first. I just bougth the car and since It was out of state I had to do alot of work so that it can pass inspection by this thursday and I'm kinda low on cash now. (tires + o2 sensor + breaks = $$$)
thanks for your help though. It was unfortunate they only had a universal sensor at the store.
Old 03-15-2005, 12:26 PM
I did a search on tuners and couldn't find much....this is all I could find. It seems that you got the right sensor (a heated one). Looking at the factory harness (on the car side not the sensor side) the wiring is as follows.
Red and yellow on the car side are the heating elements (it says that polarity is unimportant and you can hook them up either way).
The white wire is the signal wire for the ECU.
The black is the signal return wire.
You will have to look in the literature you got with the new sensor and see if they tell you which is which. The information above is for a 95, so I don't know if your's will be the same or not. You might want to give the dealer a call and see if they can verify the information.
1997 Spyder GS-T
5-Speed
Old 03-15-2005, 05:44 PM
nova1313's Avatar
Re: Re: O2 sensor wiring.
I figured out the wiring on the bosch site for the o2 sensor. The o2 has the two white ones as the heater, the black is ecu and the grey is ground.
When you mean return to ecu is that the same as ground? The two heater wires are swapable aparently as you said.
If I can get the last two wires sorted out I'm good to go and pass inspection. Thanks for all your help.
FYI I tried to search google but all I kept coming up with was how to install a logger. Which didn't help with the wiring colors (you would think it might!)
Maybe I can get the mitsu dealer to give me the info if I call tommorow. If So I'll post here I'm sure someone else had the same problem.
A link to a page that has info on the second gen o2 sensor on 1000faqs link is broken so that was of no use either.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 03-16-2005, 07:08 AM
Did you get it working? If so, was my post above the way you wired it?
1997 Spyder GS-T
5-Speed
Old 03-16-2005, 01:00 PM
nova1313's Avatar
No not yet. I can't find more info on the eclipse side of the connector. I just need to figure out which wire is which. I figure I'll strip the current sensors wires and read the voltatges later on tonight maybe that will help.
I went looking for a haynes manual but the stores around me do not have one for my vehicle and can't get one till next week which will be too late.
I'll respond when I get it with the proper wiring method
Old 03-17-2005, 11:56 PM
nova1313's Avatar
Re: Re: Re: O2 sensor wiring.
the wiring was correct. But unfortunately it wasn't that it was really my catalytic converter. Bah 470 dollars later...
Old 03-18-2005, 11:06 AM
Holy crap!!! $470 for a cat??? You should have gotten a hi-flow. Here is a 3" for $127.
http://www.slowboyracing.com/more.php?id=1466&
Why did you pay so much?
So the wiring above was correct??
1997 Spyder GS-T
5-Speed
Old 03-18-2005, 01:32 PM
nova1313's Avatar
that was installed. I dunno how to install a cat thats why I paid that much. I had todo break work myself plus new tires. I could get the parts cheap but the local stores didn't stock them and I have to pass emissions in 10 days from bringing it in the state so it had to be special ordered.
