Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-15-2005, 12:02 AM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
boosted ls once made 325 hp, needs help
my freidn bought a 90 civic hatch with a 325 ls engine, built internals, boosted 12 psi. etc. anyway. that was a whileago that the car had been like that. nowadays it feels like its only 200. his cams are at o degrees. and he doesnt believe me that we should retard his timing like 3 degrees. he saying that he just going to wait to get it "tuned prperly" now ive never had my car tuned or anything. but from basic understanding. they adjsut the cams and mess around with the fuel flow rates in the ecu. what else is done in the turnign process. and should he let me retard his timing 3 degrees?
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 03-15-2005, 12:11 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: boosted ls once made 325 hp, needs help
they dont mess with cam timing to retard. its distributor timing thats messed with electronically not phyically.
if he never messed with the fuel or the timing and ran 12psi. his motor is toast. tell him to do a compression check
Team Lonely Drivers
Old 03-15-2005, 12:42 AM
his car was dyno tuned to 325 hp, i bet the fuel and timing was tuned with that. now, i dont know waht had happened but his car became untuned, his rev limiter is not at 5500, and like i said it only feels like 200 hp, but hes been beating on it, hes raced a vette. i didnt see it, but with a limiter of 5500 i doubt the turbo and shit really would help him beat a vette. and i know he beat a sebring. so i dont know.
Old 03-15-2005, 03:47 AM
khgfd khgfd is offline
Banned
Re: Re: boosted ls once made 325 hp, needs help
toast for what
Old 03-15-2005, 04:09 AM
Re: Re: Re: boosted ls once made 325 hp, needs help
Originally Posted by khgfd
toast for what
for you to eat, what else.
and to the original poster. you didnt give us alot of info. i mean you never even said if his car was tuned at all, or even specs on the motor. you cant even verify if it was tuned accordingly or not. and my car can beat a sebring so idk what to say about that. cars dont become untuned by themselves in a sense that the programmed fuel maps dont change. something with the motor must have changed, did he add any new parts to it ?
again i would recommend a compression check, post up results
Team Lonely Drivers
Old 03-15-2005, 09:47 AM
all i know is that the motor has become untuned somehow, someone has fucked with it.
the engine is bored to about 19.5 literes (i think)
b20 crank
12 psi
internals
new 2600 lb clutch
im trying to find a pic of it, it could take a while
Old 03-15-2005, 11:38 AM
i dont need a pic, i need info on the motor. what kind of engine management does he have ? who tuned it?
one more time, do a compression check and post up the results
Team Lonely Drivers
Old 03-15-2005, 06:06 PM
he doesnt know how to do a compression check on the engine, but he says it has uberdata on it. ill search for it
Old 03-15-2005, 06:36 PM
this kind of guy is the worst guy to have a turboed motor. he doesnt know anything about car and yet he has a complicated setup like that. no wonder he is having problems with his motor
Team Lonely Drivers
Old 03-15-2005, 07:00 PM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
"ive got it...hes running 87 octane"...no just kidding...i agree with civic killer...this guy should have his license revoked, a b20 with a 19.5 liter over bore....very very possible...have it towed to a shop...he prolly skipped a tooth on his timing belt, thats what happend 2 my civic(2teeth) and it wouldn't go past 6ooorpm, and be easy when u post..calm down and take your time with spelling...
Old 03-15-2005, 08:27 PM
k, so. im at his house, he engine will now not turn over. the engine does not start. you can hear the fuel pump engage and all that jazz, but nothing. he says it could be his battery. but his lights and evverything work fine. so he says best case scenario to jsut get his car running everyday is the alternator. worst case, cracked pistons, bent rods, no compression, etc.
person who built the car says rev limiter set to 8500
3rd gear tops at 5500, and it sputters
during normal driving you could smell the unburnt fuel.
boost controller does nothing. wastegate has a 12 pound spring
Old 03-15-2005, 09:09 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
So your friend is reving an LS motor to 8500 rpms, it has a b20 crank, is bored out, and he's running 12psi of boost?
I'd say skip the compression test and just rip the head off of there to see the damage he's caused. Then rebuild the engine for the damage done, get a boost controller (even one of those really cheap ones), and run 6-7psi until it can be professionally tuned (because someone who doesn't know how to do a compression test should not be trying to tune a car themselves).
Old 03-15-2005, 10:30 PM
Banned
boost controller does nothing...does that mean u opened it all they way and then beat the crap out of it?...j/k.....so it doesn't turn over....i thnk your buddy jsut blew his motor...especially if it ran like crap days before....
Old 03-16-2005, 12:45 AM
ok, the engine wont rev past 5500, its bored out to 1.95 liters. it has built internals, sleeved block, rods, pistons etc. he had a shop put in the boost controller. and no matter how low he turns it down. the boost guage always reads 12 psi. and u can definately feel the turbo. we think the battery just doesnt have enough power to make it turn over. apparently it can be turned on with a jump start. so we think it could be the alternator
Old 03-16-2005, 02:12 AM
so then get the alt tested
Team Lonely Drivers
