Old 03-14-2005, 11:29 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
wheel spin
On 2g GST's, is the wheel spin that bad on the track? I would probably going to the track maybe 2-3 times a month, and I'm gonna mod it like hell. Besides those few times at the track, it's going to be the daily driver. The reason I ask is because there are no 2g GSX's around me, and if they are, they are either rediculously modded, or super high miles with problems, so it looks like I'm gonna be gettin a GST.
On the positive side, there are a few reasonable, cheap GST's around me, and there are no AWD dyno's around here.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 03-15-2005, 02:10 AM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Re: wheel spin
at the track i bet the wheel spin is outrageous. Because its pretty bad as a daily dirver. You really just have to know how to drive the car. Also some nice high performance summer tires will help. I'm going Yokohama AVS ES100
Something new is coming...
Old 03-15-2005, 07:36 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: wheel spin
wheel spin is a problem, wheel hop is an even bigger problem, which is bad because wheelhop not only slows you down, it makes you break things.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 03-15-2005, 07:43 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: wheel spin
I just bought really nice dunlop performance tires. They won't break lose unless i floor it in first going about 15 or higher. Tires make a HUGE difference
now - 2000 civic
soon - 2002 is300
Old 03-15-2005, 08:09 PM
What will fix wheel hop? Will the polyurathane motor mounts fix it?
Old 03-15-2005, 08:41 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: wheel spin
they help, but ideally you want to get an LSD...
The daily driver. The weekend cruiser. The lazy shop hog.
Old 03-15-2005, 10:44 PM
Ok, so lets say I get a Quaife LSD, and polyurethane motor mounts, will this make me much better?
I like that with the GST, you cant beat it on the highway unlike the GSX with the drivetrain loss, but with the lsd, will it still be like that? I also want it good for track use though.
Old 03-15-2005, 10:52 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: wheel spin
a gsx will hold its own on the highway until your going 130+ its just that the awd's are geared lower so they top out sooner. dunno about you but ariound here there isnt anywhere that i would go 130+ long enough to have a gst beat me.
you might have to drive for awhile to get a gsx. im assuming that you know tsi awd's are the same as a gsx.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-15-2005, 10:58 PM
Ya, I know they are all the same, but I prefer the eclipse body to the talon. And I also know you can convert it, but I'm still a student, and I work, so I wouldn't have the time to have that done.
Old 03-15-2005, 11:18 PM
Raz_Kaz Raz_Kaz is offline
Re: wheel spin
Have you compared Talon TSi AWD to a GSX? Usually they cost less and then you have to figure out if it will be the same to get an Eclipse body on the Talon. Around my are, I can get a Talon and put a body kit and still be cheaper than the same model Eclipse.
Old 03-15-2005, 11:22 PM
Ya, I know they are cheaper, but there are even less tsi awd's than gsx's around me lol
Old 03-16-2005, 12:16 AM
PearlGT PearlGT is offline
Re: wheel spin
keep searching, get on everyday on autotrader and look up 90-99 eclipses and talons in your area. An awd tsi or gsx will pop up eventually but its tough to find one quick I know. I used to be searching for vr-4's all the time and they were extremely scarce and now I'm leaning towards gsx's/tsi's but all of a sudden they have become scarce as well and vr-4's have shot up tremendously around my area.
Whichever you wind up with I'm sure you'll be happy to be boosting.
Old 03-16-2005, 03:09 AM
george536's Avatar
george536 george536 is offline
Re: wheel spin
If you want a gsx, get a gsx dont settle for less. youll regret it.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 03-18-2005, 12:48 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: wheel spin
AWDs are geared lower, but they still have a lot of top end. Just raise the rev limit. Shep is trapping around 165, still in 4th, with stock gearing. The lower gearing will also provide more torque multiplication rasing top speed for a given crank torque/hp, assuming both cars are aerodymically limited, as every car on this forum will be.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-18-2005, 06:09 PM
george536's Avatar
Re: wheel spin
my buddy has a 56 trim in his spyder and he doesnt spin the tires, even if he punches it hard. lol his car pulls but the turbo is too laggy so he gets traction
-1990 Eclipse GSX
