Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 03-14-2005, 10:13 PM
valve79 valve79 is offline
Question my b2200 smokes (question)
well here is somethig to figure out
I bought this truck and it had a hole in the gas tank so i fix the hole and try to start it up it has not run for about 5 months at this point.
it smokes like crazy. I asked the guy that i bought it from and he said that it never smoked before, and i know that it didnt because i seen him drive it. How can i find out what is it. Did anybody had a similar problem ?? Or m'i screwd ??
Old 03-18-2005, 06:55 PM
fishmonster13 fishmonster13 is offline
Re: my b2200 smokes (question)
does it continue to smoke after you let it run for while
Old 03-18-2005, 07:44 PM
onelow_mazda onelow_mazda is offline
I just rebuilt the head of my '87 B2200. If it somkes badly when you start the truck but it goes away after it warms up, it is either the valve seals or the piston rings. The valve seals are a pretty easy fix. Advance Auto Parts has them for like $20 or something. You will also need a valve cover gakset which is pretty cheap. If it is the piston rings, like mine is now, that's another story. Plan on a few hundred in parts and labor if you do it yourself; all but the machine work that is. If the engine compartment is looks 'dry' (i.e. no signs of oil leaking from anywhere), then it's a good bet that it's the piston rings. make sure your dipstick is in all the way and the oil drain plug is tight also.
Old 03-18-2005, 08:09 PM
89B2200 89B2200 is offline
Send a message via AIM to 89B2200
When you saw the PO drove the truck it was already warmed up so it did not smoke by then.
If it smokes during start up and goes away once warmed up, it is the valve seals or stems.
If it smokes when you step on the gas on a warmed up engine to accelerate, it is the piston rings.
The hole in the gas tank has nothing to do with the smoking.
Old 04-09-2005, 08:48 PM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
So how hard is it to change the valve seal I think that is what is wrong with mine thanks please help
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
