Old 03-14-2005, 09:32 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Unhappy having a problem...
i just recently bought an intake duct for a tpi 3rd gen... i was going to use this to connect my throttle body to the plastic intake bellows (the y-shaped piece) but i'm having a problem... the duct that i bought fits perfectly over the lt1 throttle body (since it's the same as a tpi TB) but the other circular end won't fit over my MAF (duct is too small) and the MAF also won't fit onto the bellow (y-shaped plastic piece) because the plasit hole is too small... now i can't figure out where my problem lies... i'm pretty sure that all MAF's are the same so its not because i have the LT1 MAF, are there different types of TPI intake ducts? or am i missing a piece that goes inbetween the MAF and plastic piece? is the duct supposed to be really hard to fit over the MAF? i think i might be able to stretch the duct to fit on the MAF but i don't won't to force it just incase i don't have the right piece...
please any input on what might be going on would be really helpful guys...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 03-15-2005, 03:17 AM
just moving this up to the top... i really do need help guys... if anyone has any ideas?
Old 03-15-2005, 09:57 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: having a problem...
Was the duct from speed density TPI?. and yes there were 2 kinds of TPI. There were the early MAF system and later they had Speed density.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-15-2005, 10:04 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
i was thinkin that myself, but also, why would you think that all MAF sensors are the same external dimentions? If you did get the MAF duct and it dosnt fit your LT1 MAF sensor, id say its because the sensor is a different size than that used on the TPI cars. I dont know for sure, but it makes sense to me.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 03-15-2005, 10:32 AM
FormulaLT1's Avatar
Fight the powwa!!!
I don't think they are different dimensions but I could be wrong but I hear of people swapping the MAF all the time but never heard the need to get another duct with the new Z06 MAF or any aftermarket larger MAF they get.
Old 03-15-2005, 07:02 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
check these links out
http://transamws6.com/pics/82_ta/
this guy describes how he did it about 3/4 down the page by the picture of the airbox.
http://lt1powered85z.cz28.com/custom.html
looks like you can't mix and match 3rd gen with 4th gen for the tpi airbox without custom work or creativity.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 03-16-2005, 10:43 AM
Morley Morley is offline
TPI MAF's were smaller than the LT1/LS1..beat to fit and paint to match.
Old 03-16-2005, 05:48 PM
are you sure? because that would explain everything if it were true...
