Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 03-14-2005, 09:24 PM
96RSeclipse 96RSeclipse is offline
Send a message via AIM to 96RSeclipse
Hot Amp?
im going to be putting my amplifiers under an artificial floor in my hatch... i was planing on leaving about an inch to two inches form the top pf the amp to the floor, does anyone know if my amps (2) will get too hot under the floor? should i put two of those little computer fans in the floor (one blow in, one blow out)? or maybe jsut leave alittle space or soemthing? someone help.
"I know your car is fast - You were haulin' ass when i passed you"
1996 RS Eclipse 5-Speed... R.I.P.
Old 03-14-2005, 09:29 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Hot Amp?
what kind of amps are they? how many amps? some you can just have vents in the floor others you will need fans. it also depends on how long and hard you will be running them
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-14-2005, 09:51 PM
Re: Hot Amp?
right now - 500watt rms audiobahn for my speakers and 200watt rms audiobahn for my kicker. im getitng rid of the 200watt though and putting an 800watt rms audiobahn in soon though
Old 03-17-2005, 10:52 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Re: Hot Amp?
I would put in fans if you going to be running that many amps and that much power in a tight little space.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 03-17-2005, 10:59 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
actually about 2 3" diamiter port wholes should be suffisant enuff to keep those amps cool enuff with only 1 sub
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 03-18-2005, 01:33 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Hot Amp?
i'd put a cold air intake and a larger exhaust fan.
DSM geek
Old 03-18-2005, 06:57 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Hot Amp?
Well, those cheap0 'Bahn amps have a weak power supply. So, that means it generates heat and a lot of it when pushed hard. Heat is not your friend. Make sure to have plenty of air movement.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 03-18-2005, 09:48 AM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Hot Amp?
Yeah, Audiobahn is notorious for getting really hot. I would say do what you can to keep it cool. The cooler you get it the better. You could make the false floor, except cut a whole out of it and flush mount the amps in, then it looks cool and it will really help with heating.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 03-18-2005, 02:42 PM
Re: Hot Amp?
also thought about false floor and covering the amps with plexiglass doors with holes in them. i figured that would gett the things pretty well vented and on exceptionally hot days, i could even leave the door open.
Old 03-18-2005, 05:22 PM
bighauns's Avatar
Re: Hot Amp?
That is what i am doing (plexiglass) i mean. it is going to be pimp, but i will have the xtant gear instead of the Bahn
