Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-14-2005, 08:27 PM
jerzeyjosh jerzeyjosh is offline
Send a message via MSN to jerzeyjosh
01 Explorer Sport Rear Turn / Brake signal
Rear driver's side turn signal and brake light do not work. Bulb and bulb socket have been tested and do work. Turn signal switch and Flasher Relay have been replaced. The Green/Orange signal wire going to the rear tail-lamp is not getting the signal from the dash. Green/White wire leaves the Turn Signal switch. I spliced a temporary wire from it to the tail light. That only temporarily fixed the turn signal. Brake signal is still not there.
Does anybody know where the brake signal wire, rear tail lamp signal wire, and dash board signal indicator wire connect together?? I think there is a loose connection at that point. This problem started out orignally as an intermittent problem, indicating it was not a bulb or something. Sounds like a loose connection.
Any help out there???
