Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 03-14-2005, 09:00 PM
derge808 derge808 is offline
new owner - 1999 V6 Engine light and weirdness
Hello,
I just bought a 1999 Passat V6 5-speed. The engine light is on. The engine when throttling up will pause and then surge a bit, giving the impression that I'm driving poorly. If you keep it out of gear and rev the engine, there is a pause at maybe 1400 rpm. It then catches up in kind of a slightly jerky manner. What are the most common causes of this behavior? I'm hoping on something inexpensive. Thank you.
Old 03-19-2005, 06:11 PM
boschmann boschmann is offline
Re: new owner - 1999 V6 Engine light and weirdness
Most Advanced Auto Parts and Autozone type stores will check the codes for free, that's the best place to start.
Old 03-20-2005, 02:01 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Check the engine for broken vacuum hoses. Also check by the air box for broken vacuum hoses.
Old 04-03-2005, 07:46 PM
I got it checked. Here are the trouble codes
P0123 - Throttle position sensor circuit, high input
AND
P1544 - Throttle actuator sensor, signal high
what do you think it all means?
Thanks,
Old 04-04-2005, 12:38 AM
VDUBMAN
You will need a new throttle body.
Old 04-04-2005, 10:32 PM
Ouch, that doesn't look good. Sorry, but I concur. $$! You can try checking for corrosion at the electrical connector, but it's a long shot. Unplugging it can cause other problems & it may have to be readapted to the ECM.
