Old 03-14-2005, 07:55 PM
rdwagz rdwagz is offline
Gr. Caravan leaking something
I have a 2001 Grand Caravan that is leaking a clearish fluid on the left side kind of by the tire, my guess is either the power steering fluid(line perhaps) or the rack and pinion!!! My wife said that is doesnt make any noise though!!! Any suggestions???
Old 03-14-2005, 08:45 PM
EVH5150 EVH5150 is offline
Re: Gr. Caravan leaking something
Keep an eye on the steering fluid level. Also check the CV joints too. There may be a seal that is failing. Just a guess.
Old 03-14-2005, 09:25 PM
vipergg vipergg is offline
Keep and eye on the ps fluid , there have been reports of early failure on these where the reservoir actually rusts thru and starts seeping fluid specially in high salt areas . If you have to replace it's going to cost up to $300 to get it fixed . most of it is labor .
Old 03-22-2005, 11:19 PM
yoji6365 yoji6365 is offline
Isnt the P/S on the passenger side (left sude)?
Check the brake master cyclinder. Its on the right side.
If its a bit low, you might have a leak in the brake line to the left front tire.
