Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-14-2005, 07:29 PM
stanton21's Avatar
stanton21 stanton21 is offline
Sick of looking at the cheak engine light
I have a 1500 4 by 4 and the speeddometer wont show any speed until i hit 38 mph then it shows speed,Now the cheak engin light is on and i bought a ODB11POCKET SCAN and the coade is PO500 (Veh Speed Sensor A Malfunction) so i replaced it and still it comes on after a while and the speedodmenter still wont kick in untill 38mph. Any help with this would be great.(I am sick of looking at the cheak engine light)
Old 03-15-2005, 08:11 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: Sick of looking at the cheak engine light
what year is your truck?
mine is a 99, and there are two speed sensors, one in the trans, and one on the rear dif.
the one on the rear dif is the one that is used for low speeds, when mine wend bad, I lost spedo below like 25 or 30MPH. mine did not trip the check engine light, but it did cause the "abs" and "break" lights to come on.
hope this helps ya out some,
Keith
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 03-16-2005, 12:15 AM
mikaSA120 mikaSA120 is offline
That is right p-500 is for sensor on rear diff.
But when you pull out sensor check if you have metal
particle on. If so most likely gear is going south.Rear diff
need services every 15k.Check if you need pozi-aditive.
Old 03-18-2005, 08:15 AM
stanton21's Avatar
Well thanks for the feed back,My truck is a 99 and where is this sencer located is it in top of the pig...thanks
Old 03-18-2005, 10:38 AM
yep, it's on top of the rear "pig". on mine, there is a break line clamp that is on the same stud, and needs to be removed first. it can be difficult to pull out, the o-ring seals it prety tight, it may help to twist it a little wile pulling. also, be carefull not to damage the o-ring when putting it back in.
Vehicles:
1987 Grand Wagoneer
Old 03-18-2005, 02:23 PM
stanton21's Avatar
thanks i o u a beer
