Engine cranks but wont start
My grandmother has a 1995 Escort wagon. While driving home, as she said, the engine suddenly died on her.
The engine will crank, but it refuses to start. Any ideas what is wrong? --There is spark and fuel. |
Re: Engine cranks but wont start
1999 Escort SE 2.0 ltr sohc, 5 speed - old one 1999 Escort SE 2.0 ltr sohc, auto - new one 2002 Dodge Grand Caravan sport 3.3, auto located in beautiful New England. "You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks |
We verified spark by taking each plug and touching it to a ground, then cranking the engine. There was spark.
Fuel was checked after, by removing the hose from the fuel filter's exit, and again cranking the engine. Gasoline streamed out. I was considering the possiblity of injectors being a problem, but it seems unlikely they'd all fail at once. There doesn't seem to be any abnormal sound while cranking. |
try ignition module
Re: Re: Engine cranks but wont start
Yeah, I forgot to mention, we already replaced that thinking it was the source of our problems... 200 dollars later, it still doesn't work
yeah i know chevy nova... but it was still a possibility lol, thats what it was when mine just died going down the road. and the other time is when i stripped the timing belt.
If it died suddenly as she was driving it may be worth taking a look at the timing belt.
i had i crx do that driving down the freeway....cranks over but didnt start, it was the timing belt...i dont know what motor it is but check if it is and interference motor, if so you may have some bent valves as well
yup its the timeing i'll guarantee it
Have you scanned for any Onboard computer codes? The injectors and ignition timing are fired by the EEC when triggered by the Camshaft Position sensor, and/or the Crankshaft position sensor. I would check the connectors/connections sensors and the EEC. Sensor function can be checked with a DVOM.
Alvin A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED. |
