Old 03-14-2005, 04:13 PM
Sargento69 Sargento69 is offline
Send a message via MSN to Sargento69
Help Please!!
As I Was Driving Coming Back From Getting A Hair Cut. My Car Started Acting Like It Was Loosing Power, The Stereo Started Going On And Off, Then It Finally Turned Off And When I Went To Start It It Acted Like The Battery Was Half Way Dead. What Im Asking Is Could It Be The Battery Or The Alernator??? Please Help!! Thanks....
°Sä®GëNTö69°
B20B POWERED '91CRX SI
Old 03-14-2005, 04:18 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Help Please!!
Could be a dead short.. do u have subs?? if so check to make sure the power wire isnt exposed and touching any metal, or the ground wire.
Old 03-14-2005, 04:21 PM
Re: Help Please!!
No I Dont I Just Got A B20 Put In This Week End. It Was Runnign Fine For The Whole Weekend It Just Did That Today. Also The Battery Was Relocated To The Rear A Month Before The Swap But It Was Running Fine Then
°Sä®GëNTö69°
Old 03-14-2005, 09:55 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Help Please!!
recheck all wires and fuses, also have a battery and alt test done at local shop that does it free
Old 03-14-2005, 10:20 PM
DTangent DTangent is offline
Take out the alternator. Take it to autozone, and have them test it. It's free. If it's not that, then start checking out other parts. The car wouldn't start if the battery is dead, so doubt it's that. The fact that your stereo was cutting in and out doesn't sound like the battery to me. If it's not the alternator, start probing wires.
Old 03-15-2005, 07:13 PM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
Re: Help Please!!
check to make sure the negative terminal of the battery is connected to the car
Old 03-16-2005, 07:04 AM
Re: Re: Help Please!!
hold up one min, you mean to tell me our (-) battery terminal goes to the car and not the block? if thats the case put it on the block, the negitive post being on the car caused a lot of problems on a lot of old chryslers, just a thought
Old 03-16-2005, 11:34 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
it goes to chassis, not the block
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-16-2005, 11:51 AM
mrceej mrceej is offline
Re: Help Please!!
The way you described the situation right before your car died is EXACTLY what happened to my car a couple of different times. It turned out to be the alternator each time.
Old 03-16-2005, 12:00 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Re: Re: Help Please!!
wrong buddy. grounds go to the chassis, not the motor
Team Lonely Drivers
Old 03-16-2005, 05:03 PM
Re: Help Please!!
^^ i seen that today, i also plan on undoing it and putting it on the block, where it should be
