Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 03-14-2005, 03:21 PM
BOUTO29355 BOUTO29355 is offline
P1125 Code
Hello,
I have a 2001 Trooper and have been experiencing problems with the check engine light coming on and going off alot over the course of the past few months. The problem with this is when the check engine light comes on, it is followed by the "reduced power" light coming on, and the engine immediately loses power so as there is just enough to get the car going. I kept thinking it was a gas cap issue so I would tighten it, but because it happens so much, I decided to take it to an Autozone and have it scanned. The code that was pulled was P1125. Does anyone have any ideas or suggestions on what this code means, and what to try? I can't seem to find anything on this code, except for a Toyota forum that talks about Throttle Body problems. Maybe the throttle body needs cleaning?
Thanks!
Tony
Old 03-14-2005, 07:18 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: P1125 Code
p1125: Throttle position sensor intermittent
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-15-2005, 10:08 AM
Re: P1125 Code
Thanks Ryan. Would you suggest replacing the throttle position sensor on the throttle housing then?
Thanks again for your help!
Tony
Old 03-15-2005, 12:08 PM
Isuzu Guy
Re: P1125 Code
I'm not sure if you can just unbolt it and clean it up? That might be worth a shot.
I think this is a pretty straight forward unbolt - rebolt up again.
Will this fix your problem? Maybe. It is possible that you have a leaky IMG too.
If you are looking to pruchase a new one contact the guys at St. Charles
The guys at St Charles Isuzu, have the best prices on OEM parts (free shipping). Mention you heard about them on the web and they will give you an additional discount.
Toll Free: 800-727-8066
http://isuzu.stcharlesauto.com/frame...rts_department
-Ryan
Isuzu Moderator
Car Show Tips
Old 03-15-2005, 12:22 PM
Re: P1125 Code
Thanks for the suggestion, Ryan. I'll give it a try and report back.
Tony
Old 03-17-2005, 10:45 AM
Isuzu Guy
Re: P1125 Code
http://forum.planetisuzoo.com/viewtopic.php?t=3324
-Ryan
Isuzu Moderator
Car Show Tips
Old 03-17-2005, 01:56 PM
travelman travelman is offline
If you have any warranty left, you might check with a dealer first. I seem to remember quite a few posts from owners needing a new throttle unit of some sort for their drive-by-wire equipped rigs. Of course if you have no dealer or warranty it probably cannot hurt to try a cleaning. Be sure to post back with what you do/find.
Old 03-22-2005, 09:57 AM
Re: P1125 Code
Just wanted to give a quick update..... First off, Thanks for the help Ryan and Travelman. Ryan, I purchased a TPS from St. Charles Isuzu. What a great experience. The gentleman I spoke with was great. TPS for $50 bucks with no shipping charges. That is MUCH cheaper than I could find with any local dealer in Atlanta, and they were very helpful! I will buy from them again if I need to. I decided to go ahead and just replace the TPS on the throttle housing. So far so good! I'll give it a couple more days and will report back. I really appreciate your help on this!
Tony
Old 03-30-2005, 09:36 AM
Re: P1125 Code
Replacing the TPS solved the problem. Thanks for the help!
Old 03-30-2005, 07:33 PM
rodeo02 rodeo02 is offline
Good deal Tony. Glad to hear that was the fix. Good info for others. There are several posts floating around about throttle by wire issues (2000+). I'd be willing to bet some dealers would swap out the throttle by wire system instead of just the TPS. Big $$$ mistake!
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-11-2006, 10:28 PM
koolcutta koolcutta is offline
I have the same exact problem
I have the same exact problem with my 2002 trooper 68000 miles with code P1125 I actually first got the code 10,000 miles ago but it only happened twice and then stopped happing but it recently did it three times with in 3000 miles so I figure it time i do something about it. Going by this form it seems to be my tps which is great since it seems I can put a new one in myself and i don't have to deal with a dealership and my rip-off 200 deductible for warranty service. But I have one problem i don't know where the tps is located, what is looks like or how to switch it. and to complicate things the dealer told me I have two one at the pedal and one in the throttle housing.
Is there any one that can point in the right direction or tell where i can purchase a repair manual for an 02 trooper all the parts stores around here only sell the manuals for pre 98 troopers. Thanks
Old 01-12-2006, 05:55 PM
I believe the TPS is mounted on the left side of the throttle body. Right on/near the throttle shaft. There is also a servo motor that actuates the throttle and an accellerator pedal position sensor associated with this lovely system .
G/luck
Joel
Old 01-14-2006, 10:46 AM
PeteCal PeteCal is offline
Re: I have the same exact problem
Try:
http://www.helminc.com
I bought the hardcopy version for my '98 trooper from them. I bought the CD version for my Ford van. Both were over $100 but they seem to be the same as the dealer uses.
Hope this helps
PeteCal
2007 Tucson (wife)
2014 MKX
"I am not going to live long enough to do all I want to do"
