Old 03-14-2005, 12:09 PM
Muzbgreen Muzbgreen is offline
1994 K1500 front pad replacement
Did a pad replacement 2 years ago on this Suburban now I forget how to do get the old pads out? Any help would be appreciated.
Old 03-14-2005, 01:55 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1994 K1500 front pad replacement
Most are just held in place with small clips. Pry the pads out and put the new ones in. Remember you'll need to crack the bleeder screw and press the piston back in.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-15-2005, 08:32 AM
Re: Re: 1994 K1500 front pad replacement
Thanks but what I was trying to say is how do you get the disk assembly off the rotor?
Old 03-15-2005, 08:51 AM
94 silverado's Avatar
94 silverado 94 silverado is offline
Remove the two cap screws on the back side that hold the calipers in place. I hope that helps. good luck.
94 Silverado
Old 03-15-2005, 09:30 AM
joe92k1500's Avatar
joe92k1500 joe92k1500 is offline
On my 92 I needed a hex socket for the caliper. I dont remember the size off hand.
Old 03-15-2005, 09:59 AM
Ridesagain Ridesagain is offline
I think my 97 was the same way.
1997 K1500 Z71
Vortec 350
Airaid Cold Air Intake
Airaid Throttle Body Spacer
Dual Exhaust
4" Tips-Yeah, its loud.
Dunlop Mud Rovers
Old 03-15-2005, 05:22 PM
I did that but the assembly would not slide out , up or sideways all the way seems to hang up on something?
Old 03-15-2005, 06:25 PM
As I recall, it's a real tight fit. It seems like I used a rubber mallet to loosen one side and then the other. then by rocking the assembly and applying more mallet it will come out. I can't remember for sure but I think that there's a bit of a taper towards one end of the spindle and that end of the caliper will just barely slip past it. It will come out
