Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 03-14-2005, 11:52 AM
jastokes jastokes is offline
Question Electrical Problems 2001 Bravada
I am having problems with my Drvier side front window which simply stopped working a couple of days ago? Also, I have been unable to open the left rear door from inside my Bravada for several weeks? Could these two problems be related?
TIA for any help!!!
jastokes
Old 03-16-2005, 09:05 AM
clariveros's Avatar
clariveros clariveros is offline
Re: Electrical Problems 2001 Bravada
I know this sounds stupid, but did you check the child lock on the rear door? maybe it is set to the on postition.
and the power windows, may the motor is blown or a bad connection
2001 GMC Jimmy SLS 2-door Manual Trans 2wd
120K miles and still going - (Not Anymore, ABS screwed me and at 70 mph locked the front wheels and caused me to roll it and it sits in my garage now ) members.cardomain.com/vemucla
2007 Ford F150 supercab lariat 2wd
Old 03-16-2005, 10:52 AM
Re: Re: Electrical Problems 2001 Bravada
I checked for the child lock but it was not engaged? Also, any idea where the motor for the driver's side window is located and how I can get to it???
Old 03-16-2005, 11:08 PM
derhells derhells is offline
Re: Re: Re: Electrical Problems 2001 Bravada
Not sure what year you have but I think on any vehicle the motor is behind the interior of the door, had mine off to take door off to do hinges and the motor is there 93. Get a test light to see if the current is going from the switch. I suppose you could run a jumper from the battery to the connection also and see if the motor is geting power. As far as the back door how does the handle feel? If it is free moving without any resistence then the bar/wire may have come off. You ned to take some time and take off the panels from the inside of the doors and check the internal works to find the problem.
Old 10-27-2005, 11:58 AM
MaxPlague MaxPlague is offline
I've been having the same problem with my driver-side door window as well. Heh, that's why I joined this forum.
So, it sounds like it's not a real quick and easy fix? Is removing the door panel pretty simple? I'd like to poke around in there and see what I can mess up.
Old 10-29-2005, 04:01 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
here's the procedure for removing the door panel on a 99, yours should be simular enough.
http://www.autozone.com/servlet/UiBr...3d80190d06.jsp
they also have the r&r for the power window motor at:
