| Off-Topic Talk about anything other than cars. |
Ok I went to go pick up my car this weekend and we got everything back together, It started up fine but it has no power at all The only thing that is different is the exhaust. I put it in 1st and it would hardly move. My boost gauge is reading that it vac is at 5 and its normally at 17 or so. When i step on the gas it is very delayed and will not rev above 5k and it takes a long time for it to get there. I have no idea he thought it was the timing belt on there but he went and rechecked it and thats fine. He said that all of the vac lines are all hooked up so running out of options here.
Re: Another problem
I would be more inclined to tell you it was a boost leak if this was posted in the problem diagnosis forum.
1996 Eagle Talon |
Re: Another problem
check all the piping and vac lines
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
