Old 03-14-2005, 07:31 AM
Seizer's Avatar
Seizer Seizer is offline
RH Side Radio Speakers
I lose my right side speakers when the right power door closes. While driving they come on now again. Anyone know where to start looking for the loose connection?
Old 03-14-2005, 10:45 AM
garync1 garync1 is offline
U have 4 metal contact on your sliding door clean them with an pincil eraser or electrical contact cleaner I bet it will work because I just checked for u . turned on my stereo open slide door that speaker went out closed it it came back on. Not unless one of your contacts are bad.
Hope this helps.Gary
Old 03-14-2005, 03:45 PM
Seizer's Avatar
Re: RH Side Radio Speakers
See the problem is it works ok when door is open, when it closes thats when the whole right side disappears.
Old 03-15-2005, 07:01 AM
so I asume the power sliding door is wired different,than the non power door types. do you still have 4 metal contacts on the door frame. If you do i would still try to clean them. I would also check the connects to the speaker it self. May not be so easy to get to though.
Old 03-15-2005, 07:13 AM
Seizer's Avatar
Actually I think there are 8 contacts. I did clean them with an eraser and some scotch brite, also put some dielectric grease on all metal contact surfaces.
I also think it has to do with the speaker hook up or the audio unit itself. Getting that frickin radio out is next to impossible for me.
Old 03-16-2005, 05:41 AM
DRW1000 DRW1000 is offline
Re: Re: RH Side Radio Speakers
Not sure what year you have but the stereo units are actually pretty easy to remove. (at least on my year) There is a tool available but I ground the corners of some wire coat hangers and used them. You ned to release the clips by pushing the tool into the 4 holes on the sides of the stereo and the unit slides out.
Old 03-17-2005, 06:59 AM
Seizer's Avatar
Its a 2002 model. I did buy the tools, but still the stupid thing will not release.
Old 03-17-2005, 10:28 AM
12Ounce 12Ounce is offline
I thought I would never be able to remove my radio ... even with the proper tools. I was pushing the tools in much too deeply.
Once able to look at the latch on the removed radio, I now know how little to press the tool inward.
Old 03-17-2005, 04:44 PM
Seizer's Avatar
Thanks for the insight 12Ounce.
