Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-26-2002, 01:07 PM
decora's Avatar
decora decora is offline
Question Hey! Luke...!
I have a '96 civic with proxes 205/40 zr16's on it. They have about 6,000 miles on them and my car is pretty low with no camber kit. I know that with my car lowered the lifespan on 'em isn't going to be much, but I would like to get as much as I can out of 'em. They still feel pretty new & they don't feel worn on the inside of 'em, but then I don't peel out at all.
I really don't know anything about tires so that's why I'm here. I'm about rotate 'em but I don't know which way I should rotate 'em because I heard that the tread should go a certain direction. If this is true which way? If I rotate them X style then the tread would be facing a different direction, Right? :o
Please let me know what I need to do and if I'm gonna need an allignment as well.
Sorry for the novel
Thanx in advance!!
Old 03-26-2002, 02:01 PM
Luke@tirerack Luke@tirerack is offline
Tire rotation can be beneficial in several ways. When done at the recommended times, it can preserve balanced
handling and traction of the tires and even out tire wear. It can even provide performance advantages. When
should tires be rotated ? We recommend that high performance tires be rotated every 3,000 to 5,000 miles,
even if they don't show signs of wear. Tire rotation can often be done with oil change intervals while the
vehicle is off the ground anyway. Tire rotation helps even out tire wear by allowing each tire to serve in as
many of the vehicle's wheel positions as possible. Remember, tire rotation can't correct wear problems due to
worn mechanical parts or incorrect inflation pressures. It's also important to check your owner's manual for
specific details on what method of tire rotation the vehicle's manufacturer recommends.
While every vehicle is equipped with four tires, usually the tires on the front need to accomplish very different
tasks than the rear tires. And the tasks encountered on a front wheel drive car are considerably different than
those of a rear wheel drive car. Tire wear experienced on a performance vehicle will usually be more severe than
those on a family sedan. Each wheel position can cause different wear rates and different type of tire wear.
While no one likes their tires to wear out, it is actually an advantage when all of the tires on a vehicle wear at
the same rate throughout their life. As tire wear reduces tread depth, it allows the tires to respond to the
driver's input more quickly and increases dry road performance. Since tire rotation will help all of the vehicle's
tires wear at the same rate, it will keep the tires performing equally on all four corners.
When your tires wear out together you can get a new set of tires, without being forced to buy pairs. If you
replace tires in sets you will maintain the original handling balance. And our suppliers are constantly introducing
new tires, each of which improves upon their past product's performance. If you replace your tires in sets, it
allows you to experience today's technology, instead of being forced to match yesterdays.
On front wheel drive cars, rotate the tires in a forward cross pattern (fig. A) or the alternative X
pattern (fig. B)
On rear wheel or four wheel drive vehicles, rotate the tires in a rearward cross pattern (fig. C) or the
alternative X pattern (fig. B)
If you car has directional wheels or tires, rotate them as shown in fig D.
If you car has non-directional tires that are a different size from front to rear, rotate them as shown in fig. E.
Luke Pavlick
Objects in the mirror appear ... to be losing !!!
Old 03-26-2002, 02:24 PM
decora's Avatar
Damn Luke!!
You're the man!! :ylsuper
Hey Luke !!! (G22DET) Nismoboy1 Cosmetics 2 10-19-2001 12:47 AM
For Luke, Owner Of Digital Racer AznVirus Cosmetics 20 07-30-2001 07:40 PM
Geo and or Luke - ?'s MauiBlueGRide Engine 7 07-30-2001 06:31 PM
Luke, Ive made up my mind (gomen-nasi) Aoshi1 Cosmetics 2 07-28-2001 03:38 AM
luke, check mail or sign on AIM wickedG20 Cosmetics 0 05-25-2001 12:32 AM
