Old 03-14-2005, 02:08 AM
TunerAdept TunerAdept is offline
front main seal repair
how much should i expect to pay to get the timing chain cover gasket (lower front main seal) of a 350ci v8 replaced/repaired? any ballpark figure would be nice to i know if i am getting too ripped off or not. thanks ahead of time.
2005 2.2L Ecotec Cavalier LS Sport Manual 145hp/155tq
K&N Ram Air Intake "Typhoon Intake"
*comming*
upper/lower poly mounts
header 4-2-1 1.5 primaries
remote exhaust cutout/ hi flow cat/ hi flow muffler/ larger piping
Racing Spec grounding kit
-----then the fun mods start, but one step at a time-------
Old 03-14-2005, 02:16 AM
Morley Morley is offline
$100-$200 depending on how they do it, $100 if they just drop the pan and replace the seal, $200 if they remove the pan, clean all gasket rails and put all new gaskets in.
Count on even more if they have to actually remove the timing cover, that involves removing accessories, water pump, crank pulley, harmonic balancer and finally the timing cover.
