Old 03-14-2005, 12:45 AM
AMC360Concord AMC360Concord is offline
Lightbulb whats watts?
Hey
I am looking to put a sound system in my car, a head unit and 4 speakers. For the most part, head units are 4 channels, each around 20 watts RMS and 50 watts peak. What would be an ideal speaker setup to go with this, since the speakers are rated higher? The sizes I need are 4X6 and 6X9.
Whats a good recommendation?
Thanks.
Old 03-14-2005, 10:58 AM
Brandish's Avatar
Brandish Brandish is offline
Re: whats watts?
I find Pioneer makes great speakers for the money. You can probably find a good set of two or three-ways in both sizes for a reasonable price, and they sound decent. That, and they're by far the easiest brand to work with when fitting speakers in factory locations.
Old 03-14-2005, 11:30 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: whats watts?
Do you have to use coaxials? It would be much better to do a component system....at least in the front. And I don't know how much bass your looking for, but without a subwoofer there won't be much.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 03-15-2005, 12:13 AM
Whats the advantage of component connections?
I dont know a whole lot about sound equipment.
Thanks
Old 03-15-2005, 12:08 PM
Re: whats watts?
Imaging is the biggest.... also component systems are generally etter quality then coaxials.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 03-16-2005, 02:02 AM
93-240SX-COUPE 93-240SX-COUPE is offline
Send a message via Yahoo to 93-240SX-COUPE
Re: whats watts?
A component system is basically the coaxial speaker (6.5"speaker) plus another smaller speaker like 3" with a crossover. Splits up the duties of a regular speaker to make it sound better. However component systems cost more usually and labor to install them almost doubles. Not to be mean but what kind of cheap radio are u using if it only pushes out 20 RMS. I hope that was a type-o or u just dont know, which is ok if u just dont. Pioneer is good but if there are some infinity speakers for the same price range pick those up instead. Most importantly, when u go buy them take a CD that u listen to alot and listen to it on a CD player that is the same price range as yours in ur car and listen to both set of speakers. At this point tell the speaker salesman to get the hell out of the room cuz he will trick u into thinking one sounds better. Make up your mind and then ask him/her which one he/she likes better. I used to work in car audio so I know how they think. Anyways hope that helped.
Old 03-16-2005, 02:19 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: whats watts?
I want to know what cd players you're looking at that do more than ~20rms per channel. The most I've seen is 26rms from the V-Drive Alpines, other than the claimed 60rms from the Panasonics that's a physical impossibility as far as I'm concerned.
A component set is like a coax set except instead of the tweet being mounted along the same axis as the mid (co-axial -> coax), it's a free unit that you can mount wherever you like. There are a few advantages to component sets:
1 - there's no hole in the midbass taking away cone area
2 - tweet can be mounted wherever it suits you best, if you like them pointed straight at you then point them straight at you, if you like them pointed at the windshield then point them at the windshield, you can use some tape to determine where you like them best before hand and then just mount them there when you decide on a location
3 - because components are essentially better right from the start because of the reasons listed above, companies focus all of their time and money on advancing the component sets. The coax sets are more of a side thought, they just throw them out there to please the people who don't really care much about sound, they just want a replacement for stock.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-16-2005, 08:33 AM
TFFantasy44 TFFantasy44 is offline
Re: Re: whats watts?
Originally Posted by 93-240SX-COUPE
...what kind of cheap radio are u using if it only pushes out 20 RMS. I hope that was a type-o or u just dont know, which is ok if u just dont.
Umm most of them realistically rated put out around 20, a few up to 25.
Just note if you're gonna go with a component system, your gonna need a seperate amp for them and spend some more money. Let us know your budget.
Old 03-16-2005, 11:20 AM
germanyt germanyt is offline
Re: whats watts?
these guys are right, even the highest quality h/u average around 20wrms. think about it. how small is the amp inside of a h/u? its smaller than a pack of cigarettes. not getting a lot of power from that.
