Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 03-13-2005, 11:58 PM
Powerefx Powerefx is offline
Shaved Doors
Finally bought the Shaved handle kit. I was wondering what sort of sheetmetal i should use. Copper, aluminum, how thick should it be? Where can i buy some of this sheetmetal from? And is an arc welder good enoguht to do the job because i dont want to get a welder that too powerful or it will warp the door.
Old 03-14-2005, 07:21 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Shaved Doors
Arc welders are better for thicker metal and the metal you will be welding is way to thin for an Arc welder. You should use either MIG (75% Helium or CO2 25% Argon), TIG, or O/A. You should use roughly 19 gage Cold Roll steel to fill the handle. Just space your tacks out and take your time to let them cool.
-Mike
Old 03-14-2005, 09:33 AM
Re: Shaved Doors
What about those cheap arc welders on ebay? Will they be to strong as well? And if so, what about thos flux core welders, how will they do?
Old 03-14-2005, 11:03 AM
PBking82 PBking82 is offline
Re: Shaved Doors
Yeah those chepo welders aren't worth the money. If you get one that can be converted to a TIG setup then you might have something to work with. Also, flux core prolly won't work for this. You need the shielding gas to complete the weld. Like GT said you're gonna need a MIG (w/ gas), TIG, or O/A. Hope this helps ya. Peace-
Old 03-14-2005, 11:16 AM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: Shaved Doors
If you have no experience MIG or TIG or sheetmetal O/A welding, take the car to a shop and have them do the welding.
Old 03-14-2005, 11:58 AM
mike@af's Avatar
Re: Shaved Doors
A decent welder will set you back about $400, and make sure it has a sheilding gas set up, flux core it pretty shoddy, especially when welding sheet.
Like duplox said, if you no experience welding, leave it to the professionals. Otherwise down the road your welds will crack if they arent done correctly.
-Mike
Old 03-14-2005, 06:57 PM
Re: Shaved Doors
Well, i would take it to a shop, but i want to do it myslef for experience. I mean its not like im welding two cars together. Im just supposed to weld a few "dots" spaced out, and i think those cheap TIG wealders will do. The thing will be covered with bondo anyways so doesnt make much difference.
Old 03-14-2005, 09:07 PM
mike@af's Avatar
Re: Re: Shaved Doors
Relying on bondo isnt the way to go. Bondo is only skin deep. If theres a bunch of bondo, than the paint work wont last, so on and so forth. Bondo should just be used for skim coating, and sand most of it off so theres very little left. Weld the patch entirely, sand the welds down, and if done correctly very little, if any bondo will be used.
-Mike
Old 03-14-2005, 10:10 PM
Re: Shaved Doors
If i do get it done by the autobody shop, around how much will i be looking to spend on the charge for 4 doors and a hatch door?
Old 03-15-2005, 02:42 PM
Devious Designs Devious Designs is offline
Send a message via AIM to Devious Designs
Re: Shaved Doors
Who makes tig conversions for arc welders anyone know? I got a lincoln 251 that i'd like to change over if possible...
Old 03-15-2005, 03:41 PM
mike@af's Avatar
Re: Shaved Doors
Brook, do you have the Idealarc 250? I know they make a TIG conversion for that.
-Mike
Old 03-15-2005, 04:10 PM
Re: Shaved Doors
Hmm don't remember, got it for free from my uncle, its been sitting in my "garage" for the last few years collecting dust, i know its a lincoln arc welder, rated at 251 or 250, might be a few years old... Where can i find the tig conversion?
Old 03-15-2005, 05:26 PM
mike@af's Avatar
Re: Shaved Doors
Check Lincolns site to see what you need. Then check your local retailer, or eBay.
-Mike
Old 03-15-2005, 06:06 PM
Re: Shaved Doors
Anyone can answer my question?^
Old 03-16-2005, 01:34 PM
Re: Shaved Doors
Powerefx: it really all depends upon who is doing the work and what they are doing. For all 4 doors plus the hatch, it'll prolly run you around at least $500. This may be off, but the only places around my area that do this type of work are "custom" shops. Generally these places are gonna charge you an arm and a leg to do the work (why? because they can). Peace-
