Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 03-13-2005, 11:57 PM
rav4t rav4t is offline
master cylinder
Has anyone had a master cylinder problem on their 2002 SC? I need to replace mine pedal hits the floor. Where can i buy one quick and get it sent to vancouver canada.
Old 03-14-2005, 08:51 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Re: master cylinder
Just to cover our bases, your brake fluid level is correct and have have drained the brake lines before deciding you need a new MC right?
Xterra4x4.com and the Xterra Offroad Webring
Old 03-14-2005, 10:51 PM
i did drain MC
What i found out is that the previous owner of my xterra put a bit of power steering fluid in the master and screwed it up. Do yoiu think my ABS is gone too? Rear brakes have pressure but noy in the front.
Old 03-15-2005, 03:46 AM
XTerra Guy
Re: master cylinder
Hmmmm....I would bleed the whole system. There is a part where they say to disconnect the battery so air doesn't get in the ABS. It could be a mess though. You might need to bleed the master cylinder, the ABS and all the brake lines. Someone more experienced than me would probably suggest bench bleeding everything.
For what it's worth. I would guess nothing mechanical is wrong, it's more likely what your previous owner did with incorrect fluids.
Old 03-15-2005, 05:10 PM
Do u think my ABS is toast
Do u think my abs block is toast as there are a lot of rubber seals in it.
Old 03-15-2005, 07:27 PM
XTerra Guy
Re: Do u think my ABS is toast
There's no way I could tell. I'm just on a message board. But you can bleed the ABS unit as well as the MC and brake lines. It's just a pain in the ass if you do it in the vehicle. Speed bleeders help.
Old 03-15-2005, 10:18 PM
chubbybubba1 chubbybubba1 is offline
Re: master cylinder
Bleed? You need to flush the lines and whole system with new brake fluid then bleed. All that contaminated fluid has to get out of there.
Old 03-16-2005, 12:44 PM
XTerra Guy
Re: Re: master cylinder
When I said bleed I figured replacing all the fluid "flush" was implied.
Old 03-16-2005, 10:54 PM
Re: master cylinder
That's cool. When I think of bleed, I think of cracking the nipples open to bleed the air bubbles out.
