Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 03-13-2005, 09:38 PM
autoenthus3 autoenthus3 is offline
Send a message via AIM to autoenthus3
transmission blew up
i have a 99 neon sport(DOHC) and i was on my way home from an auto show and i noticed smoke and the transmision slipping. (Its had transmision problems so slipping is usual) got home looked under the car and all of the transmision fluid had actually drained out. i got under it and cant tell where its coming from... im a mechanic but i dont know transmisions that well yet any ideas?
Old 03-13-2005, 10:31 PM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
Re: transmission blew up
uhhh check the casing for crack/hole, hole in the fluid pan your fluid pan gasket deteriorated away your fluid cooler line broke/disconnected from the radiator.
your best bet is to jack it up completly clean the trans put fluid in it and watch to see any leakage
Old 03-14-2005, 09:38 AM
yeah dude like i said... i'm a mechanic so i figured that much but i looked for all that and i think its the main seal or maybe torque convertor area
Old 08-23-2005, 10:50 PM
deadBird's Avatar
deadBird deadBird is offline
Put more fluid in, then keep a clean large sheet of white contruction paper under the vehicle when you start it. You'll get a location from which to look.
Old 08-24-2005, 07:22 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Re: transmission blew up
The original post is 5 months old...I think the problem has been taken care of.
Old 08-24-2005, 06:20 PM
yale329 yale329 is offline
could have a plugged transmission breather, did it bow it out of the dipstick. Also check your seals on each cv joint. I do think, since it was slipping before it's time for a rebuild. Everyone is right you should beable to tell where it came from.Best of luck
Old 09-17-2005, 10:24 PM
deadBird's Avatar
Re: Re: Re: transmission blew up
Gee really?
