Old 03-13-2005, 09:34 PM
jlcljayne jlcljayne is offline
Help with smoke!!!!! Did compression test.
Ok...have an 88 4dr, dx, 1.5L FI, odo reads 161k.....smokes like crazy!!!
I did a compression test and came up with 182-185 on all cylinders dry. Added oil and all cylinders went up to 270 with the exception of one that was 245....maybe put less oil in that one...
This car is new to me so not sure what the history is on the head or bottom end.
Car smokes just a little at start up...blue...definately not running rich as plugs are burning perfectly....at high rpms though...smoke billows out of this thing....
I know heavier oil will help but more interested in fixing the problem...
What are all your professional thoughts on this one??????
Old 03-13-2005, 10:23 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
sounds like valve seals are shot
not very expensive to do
Old 03-13-2005, 10:25 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Help with smoke!!!!! Did compression test.
if you have a napa and they are as good as the one around here, take the top half off and have the top end reset, not a whole lot of $$ bit of work to get to, but it should fix the problem
Old 03-13-2005, 10:27 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Sounds like you might need to get a head rebuild. Or atleast new valve seals and get your guides checked to see if their worn out. If your compression is good, the oil isnt getting into the combustion chamber through the rings, its most likely coming through the valve guides.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-13-2005, 11:07 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
182-185 is good compression. looks like valve seals
Team Lonely Drivers
Old 03-13-2005, 11:09 PM
wet test?
What do you think about getting 245-270 on the wet test?
Old 03-14-2005, 12:14 AM
you get that high because liquids dont compress so its like adding more dome onto your piston so you get more compression
Team Lonely Drivers
Old 03-14-2005, 12:22 AM
Re: Re: Help with smoke!!!!! Did compression test.
Is it likely that the problem is with the cylinder head? I was surprised to get 180's with 161k on the clock....
Old 03-14-2005, 04:00 AM
i would assume its the valve stem. a leak down test would help solve what the problem is
Team Lonely Drivers
Old 03-14-2005, 08:01 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
i think next on my list is to get a compression test to get mine to quit burning oil - hopefully my engine isnt shot :/
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
