Old 03-13-2005, 09:13 PM
mopars mopars is offline
sub questoin
Hello
I am right now in the process of making a custom sub box for my dodge dakota and curious if you can run an 12 in. sub and a 8 in. with a mono amp? thank you
Old 03-13-2005, 10:35 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: sub questoin
Don't mix and match. Get 2 10's instead.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 03-15-2005, 10:32 PM
germanyt germanyt is offline
Re: sub questoin
yeah, you dont want to do that. you would be splitting the power from the amp to each sub. and you would send too much power to the 8. assuming that the 12 is rated higher. if they happen to be rated the same and are the same impedence then it would work. but it might not sound very good.
Old 03-16-2005, 08:47 AM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: sub questoin
You will get cancellation and it will sound like shit. Look into two of the exact same subs...like stated above. peace
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 03-16-2005, 12:51 PM
Re: sub questoin
hey ng, what is cancellation exactly?
Old 03-16-2005, 12:59 PM
ngsm13's Avatar
Re: Re: sub questoin
A shortening of the term Phase Cancellation (the energy of one waveform significantly decreasing the energy of another waveform because of phase relationships at or close to 180 degrees).
Signals that are out of phase will cancel one another according to the difference in phase in degree
When two speakers are overlapped too much, playing a lot of the same frequencies...it happens. THEORETICALLY, you could crossover each properly to different frequencies...but it is ENTIRELY un-needed and with todays woofers...it accomplishes nothing. peace
NG
