Old 03-13-2005, 09:11 PM
jhaymes2002's Avatar
jhaymes2002 jhaymes2002 is offline
smoke when shifting
i have recently rebuilt a 1990 350 tbi. it has about 285 hp, and after 3,000 miles i was racing someone and he told me everytime i shift that it would puff some smoke. so i was just wondering if this was normal for a slightly hi-po motor. its just a small puff, when you start the truck it does not smoke and you can rev the motor to as many rpm's as you wnat without smoke.
Old 03-13-2005, 10:56 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: smoke when shifting
What color smoke? blueish white is oil, white is antifreze, black is gas. If it's black, it's just the extra gas in the throttle body slightly flooding the cylinders when the speed suddenly drops. Sounds like you won tho, if he saw the smoke
Also, did you confirm the smoke? Maybe he wanted you to have to tear into your truck chasing nothing.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-13-2005, 11:56 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Probably the valve stem seals. That's a sure sign of them being bad (if its oil smoke that is).
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 03-14-2005, 07:55 AM
smoke when shifting
it is white and only when you shift at high rpm's. what makes me mad, is the fresh rebuild part.
