Old 03-13-2005, 08:12 PM
pumela0220 pumela0220 is offline
95 S-10 2.2L head gasket replacement
Help me with this. I've got coolant in my engine, white "smoke" coming out the tailpipe. So I'm thinking head gasket. Keep in mind that I'm a single 48 year old female with fairly good knowledge of this stuff.....but how difficult is it to change out the head gasket myself (I do regular oil changes, tune-ups myself).
I would appreciate any and all information. Thanks
Old 03-13-2005, 10:22 PM
OverBoardProject OverBoardProject is offline
Banned
Re: 95 S-10 2.2L head gasket replacement
You'll probably easily have it done in 1/2 a day or so.
Basicly remove the throttle linkage, exhaust manifold (or flange bolts if it's easier) Remove the valve cover, then all the head bolts
Also mark any wires, or hoses that you have to remove
Do Not Touch the timing cover, Intake Manifold or water pump. Several people remove them and take forever with this small job
Clean up everything, and wire wheel any bolts that you removed
Blow out all the bolt holes with compressed air if you have it. I've used rags equally as well to clean them up but it takes longer.
Then re-assemble everything the oposite way. You'll have to torque the head the way that the book shows
If you don't touch the rocker assembly (where the valve adjustment is) or mix up the push rods (a big no-no) the valves should all still be set
Then the most important part... Dance around all your male friends that know nothing about mechanics and tell them that your smarter than them
Old 03-13-2005, 11:00 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
fairly comon problem on the 2.2l's, overboard beat me to tellen the chick how to do it, so ill just say if you need even more detale search the forum, ive seen it several times.... weve got a girl here gigity gigity gigity lol sorry
