Go Back   Automotive Forums Car Chat > Ford > Probe
Old 03-13-2005, 09:10 PM
bhoward86 bhoward86 is offline
Question engine heats up quickly and burns spark plug wires???
I just installed a new thermostat to my 91 Ford Probe, but seems like back of the engine heats up abnormally and begins to burn my spark plug wiring. Is there something else that could be causing this? I was told it was more than likely the thermostat but even after the installation of the thermostat, the back area f the engine still gets hot and burns my spark plug wiring. I'm not sure if i just have to wait a little more time for the engine to cool down or what. I let the engine run for the 10 min to mix the coolant and still it burned. Any ideas?
Old 03-14-2005, 02:05 AM
blindfoldedhope blindfoldedhope is offline
Send a message via AIM to blindfoldedhope
did you put the t-stat in backward?
Old 03-14-2005, 10:01 AM
Re: engine heats up quickly and burns spark plug wires???
Not that I know of. I put it in the same way as the old one was in. Where the spring is facing the engine.
Old 03-27-2005, 02:09 PM
I watched the back spark plugs carefully and I noticed the smoke is only coming from the back middle spark plug. What could be causing that?
Old 03-27-2005, 02:24 PM
And I think I noticed that my coolant fan doesnt come on. Maybe Im not letting the engine run long enough, but from what I see it doesn't look like it comes on anymore.
Old 04-15-2005, 02:37 PM
Sintek Sintek is offline
could be a defect in the plug wiring if it is only that wire.. unless you have actually touched or know that it is the engine for sure.. besure it's not the one SP wire
