Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-13-2005, 07:33 PM
jeff97 jeff97 is offline
serpentine belt problem
i have to change my alternater on my 97 aurora and i cant figure out how to get it off. I read the other forum about the belt but i cant find the bolt or whatever it is i gotta get too.
Old 03-14-2005, 12:12 PM
IT Geek IT Geek is offline
Re: serpentine belt problem
The serpentine belt is kept at optimal tension with a spring-loaded tensioner. So, there isn't a bolt used to remove the bolt. Instead, what you need to do is relieve the tension to allow enough slack in the belt to remove it.
To remove the belt tension, first of all locate the tensioner. Looking down at the engine from the passenger side, the tensioner is a round aluminum piece that has a square hole in it. Place a 1/2" socket extension in the hole and push towards the front of the vehicle. While applying force to the tensioner, slip the belt off the power steering pump. Then you can release the tensioner.
I would recommend not removing the belt because it is a real pain to get back into place. With the belt off the power steering pump, there will be enough slack to remove your alternator.
Old 03-14-2005, 05:13 PM
Sweet William's Avatar
Sweet William Sweet William is offline
I would recomend replacing the belt if you have not done so in the past couple of years. Your already there, why not spend the thirty bucks to avoid having it break when you need to get somewhere?
Old 08-24-2005, 04:27 PM
zephram22's Avatar
zephram22 zephram22 is offline
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
Re: Re: serpentine belt problem
Thanks, I might actually be able to replease my belt tension now!
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
Old 10-24-2005, 01:37 AM
zephram22's Avatar
Although using a breaker bar to do it is fine, I found that it was much easier to remove and replace the belt after I got an articulating serpentine belt tool for 15 bucks. It allowed me to get much more leverage, and it was able to hold the tension off while I replaced the belt.
2004 BMW Z8 3K
2006 Jaguar XJ12 1K
