97 grand am gt.......... did this 2 weeks ago... got rid of bosch plugs and instaled new wires.. ran great.. 42 psi fuel pressure .....2 weekslater same thing.. stars right of way... wont stay idling... wont accelerate either....oh the engine 3.1 110000 miles
Re: car starts fine stalls instantly
Try looking for vacuum leaks. Have you used fuel injection cleaner?
Re: Re: car starts fine stalls instantly
i tried this a.m. starting car and held ignition switch a little past spring back position . theft light stayed on but did not flash for about 15 seconds... just a coincidence or do i have a problem in my ignition switch?
the car did stay running while the theft light was Not flashing
Something is wrong with the Passlock system...
Have you had new keys cut, or a remote starter installed recently? I guess it could still be in the ignition switch itself; it's Passlock I in those cars, so there will be a bulb check wire. If it isn't triggering properly, then Passlock will shut the car off. You can test it with a DMM... It's normally a thin black wire (22AWG) in the main ignition harness. It should be going ground when cranking. |
the problem has been happening to me to and i found out it isn't what you may think what it is is the theft system in the grandam itself. What you have to do it go out turn the key over but not all the way and just leave it for 10 min. this resets the computer in the car and unlocks the theft then allowing the car to get gas and start, But it has to sit for the full 10 or it won't work.
