Old 03-13-2005, 06:22 PM
ironfish ironfish is offline
window not working, where's the fuse box
I have a 95 grand am and the windows are not working. I can't open them so i thot it could be a fuse problem but i can't find the fuse box. Any suggestions to my problem?
Old 03-13-2005, 06:48 PM
Hoags's Avatar
Hoags Hoags is offline
Re: window not working, where's the fuse box
I'm not sure about the 99's but the fuse box on my 96 is at the edn of the dash board, can't be seen when the door is closed.
Old 03-13-2005, 07:05 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
It's a circuit breaker and it should be located at the passenger side fuse box (open passenger door and you will see it at the end of the dash board). Do the windows work from any of the other switches? Is the lock-out button turned off? Are you hearing any noises when you try to roll the windows up/down? Like I said, it's a cicuit breaker, it will reset itself after it cools down, but it is possible that it has failed.
Marc
MECP Level 1 Installer
Mobile Dynamics Corp. Certified Installer
Clifford Electronics Cetified Mobile Security Installer
Electrician in training
'01 GA SE, Stock....for now.
SudburyGrandz
Old 03-13-2005, 07:07 PM
Oh crap, I thought it was a '99. So the location of the CB may not be accurate, but the trouble shooting will still be.
SudburyGrandz
Old 03-14-2005, 11:39 AM
Re: Re: window not working, where's the fuse box
Marc
Thanks I found the fuse box. the windows have been locked and won't work since late last yr. It just occured to me that it might be a fuse problem. How do I go about replacing the fuse? Where's the lock-out botton and what does it do?
Old 03-14-2005, 11:43 AM
Thanks I found the fuse box in d same spot. but still not sure if dat's d problem with the window. Got any suggestion on how to troubleshoot it?
