Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-13-2005, 04:58 PM
sleeper97 sleeper97 is offline
cams
I have a 97 non-vtec integra, and I was thinking about putting new cams (crower 402), valve kit, fuel pressure regulater ,and at some point a hondata system to tune it all. How much HP do u think I will make from this set up?
Old 03-13-2005, 09:07 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: cams
I would go with something more agressive than the 402's I would look at the 62403's on the conservative side and maybe even the 62404's. I have the 62404's and they are nice, don't have any dyno numbers though.
Old 03-13-2005, 09:50 PM
Re: cams
how is the idle with those? and if u dont know the #'s can u tell the difference alot between those and stock? and how much will the hondata system improve apon the set up? do you have vtec or non vtec motor?
Old 03-13-2005, 09:57 PM
whtteg's Avatar
Re: cams
Non VTEC motor and you will notice the difference for sure. The hondata will help a good bit to fine tune the cams. The idle has a little lope but not too bad, I had to adjust the idle from 750 to almost 1,000 rpm.
Old 03-13-2005, 10:01 PM
Re: cams
what setup do u have on ur non vtec ?
