Old 03-13-2005, 04:41 PM
Sandman22699 Sandman22699 is offline
Send a message via AIM to Sandman22699 Send a message via Yahoo to Sandman22699
Smile 99 Ticking noise
My 99 grand am se... I heard tickin noise... Went and had oil changed.. They flushed the engine, new air filter.... Still hear a ticking noise.. Was wondering if anyone could help me out.. I am ganna change the spark plugs on it tomorow... Any advice please leave thanks in advance
Old 03-13-2005, 04:47 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: 99 Ticking noise
When do you hear the ticking noise? After a cold start? It's most likely just a lifter tick. Our pneumatic lifters take a while to get the oil all the way up to them (it's especially worse when cold because oil is much thicker), and until it gets to them, they tick. If it is just a lifter tick, there's nothing to worry about.
Old 03-13-2005, 04:55 PM
nova_gh nova_gh is offline
if it only does it while your driving, might be a bearing.
Old 03-13-2005, 05:38 PM
Ridenour's Avatar
GranddAmnit
Yeh, that'd be more of a grinding / chugging sound. Sandman, could you be more specific as to when you hear the sound / how it behaves in relation to your speed / rpm / engine temp?
Old 03-13-2005, 06:29 PM
Its only when i am stopped at the light then after that i dont hear mayeb cuz of the road noise .... So should i replace the spark plug and wire's? couple friends say it might not be gettin spark so i dont know what to do .. thanks in advance!
Old 03-13-2005, 06:48 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
Click click click click, I'll bet you have a dual overhead cam quad 4? Like ridenour said, lifters will tick, and varies depending on driving habits. I've owned two different makes of DOHC engines and the only reason I can think of as to why the ticking is much more apparent on these engines is because DOHC for one have more lifters which equals more of them making the noise and second the lifters are located right on top of the engine as opposed to being buried in it's belly where the noise becomes more muffled as in the case of non-overhead cam engines. HTH
Marc
MECP Level 1 Installer
Mobile Dynamics Corp. Certified Installer
Clifford Electronics Cetified Mobile Security Installer
Electrician in training
'01 GA SE, Stock....for now.
SudburyGrandz
Old 03-13-2005, 07:29 PM
Ridenour's Avatar
GranddAmnit
^ ^ Right on marc - that's most likely what it is, Sandman
Sandman, is it possible it might even just be a component of your dash rattling? A while back, I thought I had a bad bearing that I was hearing at idling, except I slammed my hand down on top of my dash above my instrument cluster, and the rattling sound stopped - so apparently it was just something loose in the dash.
Old 03-13-2005, 08:04 PM
it only does it some time's not all the time.. I am ganna try to see if its getting smark.. i dont think its a quad 4... i am ganna have my mechanic work on it.... anyone else have advice send me a msg on yahoo or aim thank's for the advice.. if it is the lifts that a bog job aint it? i hope its not that.. but thanks guy's!
Old 03-13-2005, 08:19 PM
It may be something you just have deal with, I haven't heard of any fixes for the dreaded "click". If you come across something let us know.
SudburyGrandz
Old 03-13-2005, 08:41 PM
Martina Martina is offline
I'm having the same problem with my 99 Grand AM SE 4 ltr. V6.
It will tick like mad when I first start it up. After I drive for a while the ticking will subside and eventually stop.
It's very LOUD on starting. Generally only happens when it's cold outside. I have really noticed this moreso lately than before.
Should I be concerned. Is there something else I should be checking to make sure it's not the actual engine ready to blow?
Thx
Old 03-14-2005, 06:22 AM
Ridenour's Avatar
GranddAmnit
^ ^ It's most likely a combination of lifter tick and piston slap - this is common when it's cold outside. I wouldn't worry about it.
Old 03-14-2005, 02:54 PM
I think i fixed it
hey guy's! Put the new spark plugs in seems to be doin well for now ... Couple were loose and not really bad.. but replaced them anyways.. So thanks for the free advice i will be back to check out some stuff on here.. have a good day
Old 02-13-2006, 10:20 PM
Mysty Mysty is offline
Unhappy Re: 99 Ticking noise
I have also a 99 grand am se. V6....I love my car, but the noises....I have a loud chirping noise, started out as only when it was 1st started. now its all the time. I was told it was the power steering pump, but i dunno. Also i have the ABS and trac light that comes on. I feel the car surge for like a second, then both lights come on, its getting annoying, can anyone help??? thanks
Old 02-13-2006, 10:21 PM
BTW, i had an oil change, tune up w platinum plugs and new wires...still nothing
Old 02-13-2006, 11:40 PM
97grandamld9 97grandamld9 is offline
Banned
what oil filter are you using, some of the cheap filters like fram and what not that most of the quick oil change places use cause louder engine sounds. If you are using a cheap filter like fram and the like, i would try an AC delco filter, they usally get rid of some of the noise.
