Old 03-13-2005, 04:36 PM
jerry_smith jerry_smith is offline
Very weird steering squeak
Ok,
my 99 silvy has developed a strange squeak when i turn the steering wheel left or right. It sounds like a gear grinding or rubber squeaking. Is there something in the steering assembly that can be greased? Or some kind of gear to go bad and cause the squeaking/whining noise when i turn? I dont have any of the vibration or "clunk" other silvy owner's complain of, just this really annoying sound... anybody know what to do?
thanks,
jerry
99 Silverado, Ext-Cab, 2wd, LS, 5.3
Mods:
1. True Dual 40 Series Flowmasters, both mounted vertically in the fenderwell with turn downs.
2. K/N FIPK Gen II, with removed MAF screen
3. 4-headlight mod, with all 4 being 9005 65w Silverstars
4. Matrix 25 LED daytime running lights
5. Superwhite LED's in lic. plate, cargo, backup, and sidemarkers
Future mod plans:
1. Electric LS1 fans w/ nelson harness
2. Nelson PCM
3. Underdrive pulleys
Old 03-13-2005, 08:09 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Very weird steering squeek
grease all the balljoints & other steering stuff. most times it's the lower balljoints that squeak. you should also check them for play by jacking each wheel off the ground by the controll arm. try prying the wheel up& down and shacking the tire from top to bottom. a little up & down in the lowers is alowed but no side to side and no movement in the uppers.
Old 03-13-2005, 11:59 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
yup...ball joints
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 03-14-2005, 01:15 AM
airjam18 airjam18 is offline
I've got a real annoying squeak coming from my front end too....i'm gonna check the ball joints tomorrow if the weather stays good....
Any specific pointers on greasing the ball joints...like are there grease fittings or do i need to spray some white lithium or silicon lubricant in there?
Old 03-14-2005, 03:19 PM
bowtieguy bowtieguy is offline
simple just grease, but raise your truck so the wheels are off the ground first.
2002 Z71 ext. cab LT trim
badgeless
Rhino spray in liner
Stock for now, other than free mods
future plans (how far in the future depends on wallet)
Toyo Open Country M/T's
air intake (not sure which yet)
exhaust system (seems that Magna flow is the ticket)
Nelson tune
3 or 4 inch lift
Old 08-22-2005, 12:48 AM
TXAGG05 TXAGG05 is offline
Sorry to bring back this really old thread, but I needed a little more info. My truck makes a sick metal on metal rubbing noise when I turn, but only when I turn left. I greased all 11 or 12 fittings per the Chilton manual but it didn't solve the problem. It almost seems like the squeak is coming from the steering column before it gets to the intermediate shaft. Anyone experience this problem? It's been getting worse, and it is driving me nuts. Also, it seems the sound is sometimes accompanied by my belt squeaking about once a revolution during the turn.
Thanks,
Jeb
-- It's nice to be back in the land of internet at home!
2002 Chevy Z71 Ext Cab, Black
2004 Blue Wave 180-V, 90hp Yamaha Outboard
Pre 1960 Duck Boat, 9hp Mercury Outboard
2002 Argo Conquest w/ tracks
Also driving, but not at my house:
2001 Pierce Saber
1989 Pierce Dash
(See Pics in my gallery)
Old 10-27-2005, 07:02 PM
bjmpepper bjmpepper is offline
I have the same problem too. It's almost like a bushing in the steering problem that needs grease. The problem rarely occurs, but when it does it is when the steering wheel is turned quickly to the right or left. The sound is definitely coming from the column; not the ball joints, etc.
Old 10-27-2005, 07:22 PM
yakk's Avatar
yakk yakk is offline
Might it be this?
http://www.automotiveforums.com/vbul...d.php?t=265506
Old 08-08-2007, 11:50 PM
c/kman c/kman is offline
Hey, i just read this forum and I was wondering if you ever did fix or get rid of that damn squeak. That thing has been driving me nuts for 8 months now and ive tried everything but i just cant seem to find where the damn thing is coming from. If you can help me please write back and let me know
Thanks
Old 08-09-2007, 08:24 PM
lweford lweford is offline
I have this very same problem with my '99 but to me it sounds like the power steering pump, when "loaded" or has a strain on it, is sweaking. I've already checked belts, ball joints, intermediate shaft. This is my best guess now. Let me know if any of you GM Techs have heard of this.
