Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-13-2005, 03:56 PM
krue92 krue92 is offline
Vibration after clutch install
I just recently installed a clutch in my 95SE Maxima. After the install I started the car and it seems to be a vibration at around 1k rpms. It seems fine at about 700 rpms or in the upper power band. The clutch feels fine and shifts great. I have about 30 miles on the new clutch. The clutch I installed is the Exedy stock replacement. I had the flywheel turned. I really don't know where to start. Should I break in the clutch more and see what happends? Any ideas? Thanks.
Old 03-13-2005, 06:05 PM
thrasher thrasher is offline
Re: Vibration after clutch install
Hmmmm...what about the vibration damper, did you remove that in the process for some reason and not get it back in straight? IIRC, the bolts on the flywheel and clutch have to be tightened in a specific sequence to prevent cracking and ensure even torquing of the bolts. Did you do that?
"Don't have sex man. It leads to kissing and pretty soon you have to start talking to them."
Steve Martin.
Old 03-13-2005, 06:26 PM
I tightened the bolts in a cross pattern like it suggested. Where is the vibration dampner at?
Old 03-17-2005, 07:53 PM
Lanzy61 Lanzy61 is offline
I had a clutch replaced on a starlet by a mechanic i took it back a day later cause it was almost impossable to drive due to vibrations in the low rpm range he just told me to break in the clutch and now its all good
Get Some Bog And Fix Your Turbo
Old 03-17-2005, 08:16 PM
Re: Re: Vibration after clutch install
So it was that bad and now its fine. How long did it take for it to stop vibrating. Thanks.
Old 03-21-2005, 02:26 AM
about one week but it was a dirty old starlet so i broke it in pretty roughly (skids lol) so maby about 2 weeks for you
