Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-13-2005, 04:41 PM
mai0f mai0f is offline
urgent, need help please
whassup guys?
ok... here's the thing... my car's broke down at starbucks down the street.... and i need to get it out of the parking lot ASAP
it's a 1987 nissan 200sx, 4 cyl, CA20E, auto tranny
has new sparkplugs/wires/dist cap/oil is good,air filter, fuel filter
i cant figure out what's wrong with it...
the starter cranks, you can hear it trying to start, but it wont... batt is good, only thing i see was the number 2&3 start plugs had a small dribble of fuel, and were loose.... but i tightened them....
any suggestions??? please??
thanks,
mai0f
Old 03-13-2005, 06:48 PM
SHIFT_KA24DE's Avatar
SHIFT_KA24DE SHIFT_KA24DE is offline
Re: urgent, need help please
well if it's not the battery... you can't jump start
if it's auto you can roll start... (not sure wat it's called)
unless you find a loose spark plug or something just tow the sucker
Old 03-13-2005, 10:50 PM
Chuki_breath Chuki_breath is offline
roll start an auto??? i thought only sticks could do that?
Old 03-13-2005, 10:56 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
yeah ive done it on manual atv's but ive never heard of that in an auto before...
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 03-14-2005, 12:10 AM
yeah...i pushed it home about 1/4 mile with my dad's 84 accord....
i got it to start for like 3 sec, then it just died....
i changed the distributor cap and rotor the night before, but i was able to drive it to autozone and back that night, then this morning i made it to starbucks and when i got back to my car it just said "Fah-Q"...my wife said maybe someone put something in the gas tank, but you cant open it from outside..... i just filled it up 2 days ago.... (damn $2.07 regular)
i took the distributor cap off tonight and inspected it, and there's no way i can put it on upsidedown......
bah... i'm soooo noob to cars... if anyone has any suggestions, please PM, email, call, knock on my door.... ANYTHING!!!
thank you all much,
mai0f
Old 03-14-2005, 03:26 PM
NiSmO_zt's Avatar
NiSmO_zt NiSmO_zt is offline
Send a message via AIM to NiSmO_zt
did you check the rotor again? i had that happen before, if you dont tighten the distributor rotor right, it will come loose, and lose contact with the caps contacts = no worky, it baffled me just the same as you. always start with the last thing you did to the car.
my current 240--ka-t
Old 03-14-2005, 03:36 PM
lolz... shiet.. my fault. I meant to type "if it's an auto ... you CAN'T roll start.."
i think i was trying too hard to remember the correct term so i forgot to include the can't. I was trying to make it sound horribly dreadful for mai0f.... haha.
1993 RMS13 5MT KA
Old 03-14-2005, 04:10 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
How about ur...uhmmmm...FUEL?? How is the pump?
i mean there are 2 things that i think is wrong with the motor then :
Electrical related Problems
-spark plugs, ECU, weirs... (no ignition)
Fuel related Problems
-injectors, fuel pump, leaks (no fuel)
u did the tune up, and your alternator and starters are ok, so noting else comes to mind. Except for those 2 things I mentioned.
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 03-15-2005, 12:53 AM
i'll look at the rotor morrow morning...
as for the fuel pump/fuel sys... i hope not....
i dont have too much money to invest in it right now,
mai0f
Old 03-15-2005, 02:50 PM
bah..... nothing, i took the rotor off and inpsected it.... compared it to the old one.... the old one looked like it been through a fire... lol....
used some locktite, it's all clean.....
i also took the batt to autozone to get it charged cuz i drained it pretty bad trying to start it so much...
i know that the rotor turns when i crank it,
hmmm.... how can i check to see if the spark plugs are getting current? i dont have a multimeter....
thanks,
mai0f
Old 03-15-2005, 06:20 PM
NiSmO_zt's Avatar
just pull one of the plug boots off of a spark plug and put an old plug into it, then lay it on the valve cover or intake so the body is grounded(metal ring touching metal engine part), and turn the motor over wiht ignition, it should spark if its getting power.
Old 03-20-2005, 12:05 AM
well.. i bought a new batt for my car, and it started... i ran it for 10min and it ran a little rough....
later that day i tried starting it and it didn't start....
so i went back to autozone, traded it (4 hours old)and paid $1.06 extra for a batt with 200more cold cranking amps than the other one.....
and still wont start... i thought it was the alt, but it wouldn't start with the better bat...... BAH!!!!!
any suggestinos?
thanks,
mai0f
Old 03-20-2005, 01:09 PM
slideways240's Avatar
slideways240 slideways240 is offline
Send a message via MSN to slideways240
id check your injectors. my old geo storm, lol P.O.S, anyways it did the same thing and i went through everything you are, i even bought a new pump for it, turns out it was just injectors, oh and then make sure you have got all the plug wires going to the right plug, it might help. but the way you describe it sounds like its not hittin all pistons, so id definately check injectors if you havent done so.
Old 03-20-2005, 01:12 PM
Dirttracker18 Dirttracker18 is offline
Dude you're grasping at straws here, take a step back and a deep breath.
First off, if it is cranking over then it is not the battery or the alt. You could have saved a chunk of change by not buying a new battery and more cranking amps willnot help the engine run or run better.
Since this started just after your tune up, take everything apart that you did and make sure it goes back together the right way. Even better if you still have the old parts put those back on and see if it works like that.
Barring that is sounds like a fuel problem, unfortunately the money spent on the new battery could have paid for a fuel pump. You will need to check to make sure the fuel pressure is up where it should be, you will need a spec sheet or manual to determine proper pressure. it culd be as simple as changing the fuel filter (you did do that when you changed the ignition parts right?).
Go step by step, it seems like a hassel but you can otherwise spend a ton of cash that could have stayed in your pocket.
1. Retrace steps of tune up, try old parts
2. Check fuel pressure, if low change fuel filter first then go to pump (filters are cheap)
3. Start looking for loose connections everywhere under the hood (perhaps something you accidentally touched, hit, knocked when doing the tune up.
Step by step and stop throwing parts at it.
hoep this helps you out and good luck.
Old 03-20-2005, 07:21 PM
well... the car sat for 6mo without running, and i had to take the batt to autozone two or three time for charging because it wouldn't hold it's charge more than a day or two....
i still have the old distributor cap and rotor, i've compared the old with the new, and they're EXACTLY the same except for the "nissan" logo on the cap and the bar-B-qued inside of the old one... i mean it was BAD....
one thing i did that i'm not sure if it'll affect it is, i put some of that "boot protector" grease that's for the spark plugs in the wires on the distributor cap....
i have changed the fuel filter... the fuel that came out the old one
looked like muddy water..
if i let it sit a while, the fuel line going to the engine can be squeezed, but after i try cranking it, it's hard.... doesn't that mean the fuel pump is good?
but what i dont understand is that it i drove it a good 3-4 times before it just crapped out.....
thanks,
mai0f
