Old 03-13-2005, 04:11 PM
kallenbach_05 kallenbach_05 is offline
Brake Drums
how do I remove stuck on brake drums so I can check the brake shoes?
Old 03-13-2005, 05:57 PM
nova_gh nova_gh is offline
may have to drain your brake fluid. even without locked up brakes, you'll going to need to do a lot of prying.
Old 03-13-2005, 06:01 PM
what good would that do?
Old 03-13-2005, 06:21 PM
Hoags's Avatar
Hoags Hoags is offline
Re: Brake Drums
To remove the brake drums, do not set the parking brake. Jack the car up with wheel chocks or something solid to block the front wheels so the car can't move when it is jacked up. After jacking up the car put a jack stand under the car in a solid area so the car can't fall. Remove the wheel that you want to check. If the drum does not pull off easily you may have to hit it with a hammer sometimes this will help to free it up. that usually works. I have sprayed wd-40 around the center of the drum to help to get it to slide off.
Hope this helps.
Old 03-13-2005, 06:22 PM
i hit it with a hammer and used wd-40 but it won't budge.
Old 03-13-2005, 06:45 PM
lc6888 lc6888 is offline
I have the exact same problem on my GRAND AM!!, I tried WD40, hammers, etc but it just wont move on my 99 GRAND AM SE. somebody please help!!
Old 03-13-2005, 07:14 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Brake Drums
If WD-40 didn't work you may need something different try PB Blast which is a catalyst that disolves rust. Spray around the hub center and each lug nut. Check the backing plate to see if it has an adjustment opening. If it does you may need to back off the brake shoes as far as you can get them due to a lip build up on the drum due to wear. Make sure there aren't screws holding the drums in place like on Fords I doubt that is the case but anything is possible. You may have to resort to renting a large puller and pull the drum off if the hammer method doesn't work. Good Luck!
Old 03-13-2005, 07:25 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Brake Drums
Let it set overnight in breakaway - break-away is very powerful stuff. It's never let me down.
