Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 03-13-2005, 04:07 PM
nialusa nialusa is offline
Send a message via ICQ to nialusa Send a message via AIM to nialusa Send a message via MSN to nialusa Send a message via Yahoo to nialusa
3sgte engine VSV valve/iduction question.
I`m in the process of producing my own induction kit and cold air box set up for my ST205. A couple of questions.
Obviously I`m getting rid of the standard airbox and dumpvalve. Fitting the dumpvalve isnt a problem, but there is a pipe that connects to the top of the airbox Marked as "D" on picture 2 this comes from position "A" on picture 1 Is this the pipe that leads to the wastegate VSV valve that I have seen marked on some repair manual drawings???? Is it possible to connect this to position "C" without causing ant damage as the pipe that leads here normally, is just the breather pipe for the engine "B" which I can just divert and top off with a small filter.
If I`m incorrect with my assumption what is pipe "A" and what can I connect it to?
or basicaly - can I connect point "A" to point "C" and not break my car?
Hope this makes sence, any help will be as always much apreciated.
Cheers folks
