Old 03-13-2005, 02:03 PM
dholly_oh dholly_oh is offline
Send a message via Yahoo to dholly_oh
95 s10 ls 4x4 transfer case help?
I have a 95 s10 4x4 ls 4.3l with overdrive and its stuck in 4x4 low. I put in a new vac vale into the transfer case and it is still stuck in low and I cant get it out?
Old 03-13-2005, 05:10 PM
Danlorus Danlorus is offline
4x4 stuck
Check your fuses, if those are all set. There is an actuator under the battery, it looks like a little drum covered in rubber, that may also need to be replaced. Try squezing it to see if you can force it out of 4 wheel drive. You will need to pull the battery to get to it, but it is located right under there atleast in the 97 model.
Old 03-13-2005, 08:57 PM
troy1 troy1 is offline
AF -Advisor
Re: 95 s10 ls 4x4 transfer case help?
Is the T-case electric shift or manual lever on the floor? I have seen the motor go bad but more often the switch goes bad. also make sure you got the vaccum line connector hooked up right!!!!
Old 03-14-2005, 05:01 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Check the stuff the other people said to check, but you could also have a bad transfer case motor... Disconnect the battery for 5 mins and see if that resets it.
Old 03-14-2005, 10:37 AM
Thanks
Thanks for the advice and i'll give them a try and see if it works. It is the push button type.
