Old 03-13-2005, 01:51 PM
ES199331 ES199331 is offline
Question freeze plug
Hello everyone! i have a 95' cavalier and i am having troubles getting my freeze plug out. it is rusted around the edge and i have tried everything to knock it out. anyone have any suggestions.
Old 03-13-2005, 02:15 PM
TunerAdept TunerAdept is offline
Re: freeze plug
break a hole through the middle, pry it out with a pry bar after you made the hole.
2005 2.2L Ecotec Cavalier LS Sport Manual 145hp/155tq
K&N Ram Air Intake "Typhoon Intake"
*comming*
upper/lower poly mounts
header 4-2-1 1.5 primaries
remote exhaust cutout/ hi flow cat/ hi flow muffler/ larger piping
Racing Spec grounding kit
-----then the fun mods start, but one step at a time-------
Old 03-13-2005, 02:26 PM
public's Avatar
public public is offline
Re: freeze plug
Yep, don't be afraid to destroy the old one. I have used the above method many times.
Yes, I am retarded.
Old 03-14-2005, 11:24 PM
deadBird's Avatar
deadBird deadBird is offline
Re: freeze plug
Why would you need to remove the old one?
Old 03-18-2005, 07:24 AM
public's Avatar
Re: Re: freeze plug
Rusted hole in it. I have never seen a case to put one in where I could leave the old one in.
Yes, I am retarded.
Old 03-18-2005, 03:00 PM
deadBird's Avatar
Re: freeze plug
How does that affect the engine?
Old 03-18-2005, 04:31 PM
cousincletus cousincletus is offline
Re: freeze plug
I use #1 permatex around the new freeze plug before I pound it in. Keeps it from leaking around the edges.
Old 03-19-2005, 06:25 AM
public's Avatar
Re: Re: freeze plug
What do you mean? Do you know what a freeze plug is? It is a metal plug put into the casting holes in the block. These holes are there to let the casting sand out and they open into the cooling jackets. If your freeze plug is bad it will leak coolant. If it is not leaking coolant then it is not bad. Let me know if you still have any questions.
Yes, I am retarded.
Old 03-19-2005, 08:36 AM
Re: freeze plug
well put public
*comming*
